New Battery, or recharge?
Old Aug 25, 2016 | 05:04 PM
1993C4LT1's Avatar
1993C4LT1
Default New Battery, or recharge?
I left my interior lights on all of last night, till this morning. Multimeter reads the battery voltage a 7.2
Is it OK to recharge it, or do I need to buy a new one?
Old Aug 25, 2016 | 05:08 PM
bjankuski's Avatar
bjankuski
Recharge
Old Aug 25, 2016 | 05:10 PM
1993C4LT1's Avatar
1993C4LT1
Old Aug 25, 2016 | 05:31 PM
antfarmer2's Avatar
antfarmer2
Recharge fully jumping can damage.
Old Aug 25, 2016 | 05:35 PM
1993C4LT1's Avatar
1993C4LT1
oh no trust me, I won't jump it.
Old Aug 25, 2016 | 05:45 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Recharge it and test it with a $20 batt tester.
Old Aug 25, 2016 | 09:47 PM
aklim's Avatar
aklim
Recharge and bring to Batteries Plus for testing. Fast charge a few hours till it is done, trickle all night long.
Old Aug 26, 2016 | 08:58 PM
Purple92's Avatar
Purple92
Absolutely no harm in trying to recharge it. Just avoid the higher amperage settings on the big chargers - the only way to get a battery to accept 20 - 50 Amps is to push the voltage WAY up, and that's not the best thing for the battery.
After recharging - it certainly wouldn't be a bad idea to do a load test on it - many places will do that for free.
Old Aug 26, 2016 | 09:49 PM
pcolt94's Avatar
pcolt94
You're in a hot place as I am and 2 or 3 years on a battery time is running out. I'm sure you can charge it and all will probably be OK. If you run the car several times a week it will stayed charged and will never see the difference in getting it started.
But the real difference is the reserve power. If you ever lost the alternator of broke the belt you would be running strictly on the battery. If there's not much reserve left, you'll be sitting on the side of the road and not make it to your destination.
The heat really take a toll on the battery and depending on the age you will have to decide which way to go at this time.
Old Aug 26, 2016 | 10:00 PM
1993C4LT1's Avatar
1993C4LT1
Got it charged. It doesn't go below 14 volts at idle, in gear with a warm engine. Before I left the lights on the other night, it would go to like 13.2 volts with all accessories. Now just 14. Is that bad?
Old Aug 26, 2016 | 10:07 PM
antfarmer2's Avatar
antfarmer2
If any doubt take it in for a free load test.
Old Sep 1, 2016 | 01:40 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default charge
I see above 14 on my 1985 and 1996 while driving.
Old Sep 1, 2016 | 05:34 PM
bjankuski's Avatar
bjankuski
No, this is really an indication of your alternator not the battery. The battery appears to be fine and your alternator is fine.
Old Sep 1, 2016 | 07:00 PM
1993C4LT1's Avatar
1993C4LT1
Yes, forgot to update the thread. Battery voltage is just as I remember it now.
Old Sep 1, 2016 | 07:35 PM
antfarmer2's Avatar
antfarmer2
Good job and thanks for the update.
Old Sep 3, 2016 | 04:31 PM
ddahlgren's Avatar
ddahlgren
OK not to hijack but I have a battery that runs down in around 3 weeks hooked up. Charged at 15 amps for 4 hours and claimed charged and then 2 or so amps for 6 and never reached charged and hooked up to nothing. Will try a 2 to 6 amp charger tomorrow for a few hours. off the charger 12.91 volts 24 hour later 12.61. Checked standby load at under 30 ma. Is it the charger or is the battery a bottomless pit or junk?
Old Sep 3, 2016 | 04:48 PM
SELLC's Avatar
SELLC
You should hook up an amp meter and see how much the system is pulling. 50 milliamps is about the max, if it's over then you know you have an excessive draw, under or about even and you know the battery is just starting to degrade.
Still, three weeks is a long time to sit. I'd check how much the car is drawing and go from there.
To New Battery, or recharge?
Old Sep 3, 2016 | 04:57 PM
ddahlgren's Avatar
ddahlgren
I stated it under 30 ma. reading is helpful for the reply.
Old Sep 3, 2016 | 05:01 PM
SELLC's Avatar
SELLC
Standby load? Ooooookayyyy...
So you get the point... What's your problem then?
Old Sep 4, 2016 | 12:42 AM
ddahlgren's Avatar
ddahlgren
Doing some research the average car battery has a 40 amp/hr. standby to power something and still be useable to start a car. 30 ma is 21.6 in a month so should easily start up. The other is the battery never seems to get to the point the charger says it is charged. Will try a different charger tomorrow.
