86 Vette won't start
Old Aug 29, 2016 | 06:03 PM
Fatdesoto's Avatar
Fatdesoto
6th Gear
Default 86 Vette won't start
I replaced the stock injectors with 42 lb. Mustang injectors. I drove it for 3 hours but it still ran rough, it wouldn't compensate. The next time it started it had smoke coming from underneath and from the dash vents. Now it won't start. I checked the spark at the plugs with a spark checker, checked fuel pressure with a gauge and the injectors with a tool made for that. Everything was OK. It has had the key resistor bypassed. Still won't start. Any ideas?
Old Aug 29, 2016 | 07:10 PM
antfarmer2's Avatar
antfarmer2
Call Jon at FIC and get the right injectors you just missed the sale. I would check your oil for fuel you do not want a grenade.
Old Aug 30, 2016 | 02:30 AM
Cliff Harris's Avatar
Cliff Harris
42 lbs is way too big. The ECM can't compensate for injectors that big. When you're in open loop mode the ECM will make the injectors pulse as if they were 22 lb injectors and put way too much fuel into the cylinders. You will run super rich.
Old Aug 30, 2016 | 11:29 AM
Vic'89's Avatar
Vic'89
Did you get a tune for the 42 lbs Injectors ?
If not, then you just flooded the Cylinders.
Vic
Old Aug 30, 2016 | 11:46 AM
Fatdesoto's Avatar
Fatdesoto
6th Gear
Vic
No I didn't. From what I read in forums the ECM would learn itself. Guess that was wrong, looks like I will have the originals cleaned, replace the o rings and reinstall. Thanks for all replies.
Old Aug 30, 2016 | 01:47 PM
antfarmer2's Avatar
antfarmer2
Better and cheaper to talk to Jon. change the oil.
Old Aug 31, 2016 | 11:47 AM
Vic'89's Avatar
Vic'89
Stock Injectors are 22 lbs , you just doubled the amount of fuel being dumped into each Cylinder.
I am pretty sure all the plugs are wet. Pull them and check them.
Vic
To 86 Vette won't start
