Cooling fan considerations
Oh well. I'll go back to not worrying about air pockets in my early LT1.
Maybe I should add another one that reminds us you can typically use more advance at 185-deg versus 205-deg. (Yes, the site is for Mustangs, but it still applies.)
Even our vette's have reduced timing as the temperatures go up, (which means reduced power). I have attached the timing retard curve vs. temperature on a stock 1989 vette. As it shows the timing starts to get retarded after the water temperature exceeds 197 degrees. (The numbers from one cell to the other are linear interpolated so by 208 degrees you have 1.6 degrees of timing pulled at higher load values)
I spent quite a bit of time trying to consolidate the things I've learned about cooling along with the hard-to-find considerations when looking into cooling issues. From what I know, they may be more prevalent in the L98 because air flow and the stock fan are "borderline".
In looking at fans, I found the topic very complicated. Aptly, some people would argue just throwing parts at a problem is a bad/costly approach. I agree because I don't like doing things over.
The issue of fans is challenging because it's not obvious "how much" fan might be needed for improvement. I've compared what my car does at intervals from stop to 40mph...and higher. I've read people using wind meters to see what fans put out. I "Googled" and found little about thickness of radiator versus static pressure. Documentation on fans can be sketchy, inadequate, or contradictory.
Then you have to look at the dimensions/compartment of what you are dealing with. Will dual fans work/fit? Is it better to stick with the stock configuration? Are there ANY fans that will provide enough bump to really meet your target/goal? What about wiring and amperage supply from the stock system? If you want better cooling at idle, is an electric water pump the better option? Are high-flow water pumps any better...especially at lower rpms? I also mentioned cleaning and provided a link to a few related threads with their own level of feedback/detail.
I was actually surprised how much looked, digging, and research I've had to put into this subject to figure out my options. After doing so, it just seemed obvious there needed to be a consolidation of this information. That's why I contributed this thread...and especially the OP.
As I more forward, I'm ruling out some of the options I originally hoped to be the best ones. People don't post important things like aftermarket power usage of fans (like Mark VIII) versus the "real thing"). Like any other "knock-off", copies might not perform the same. Chinese-made is...and Chinese-made does! [wink]
Yesterday, I was really hep on the idea of converting a late-model dual fan setup to my earlier car. Now I don't think it will work because later cars have a "slanted mounting" which allows for a taller setup. The late model fan shrouds are too tall in an L98. (And the fans "sit" all the way at the top/bottom -- eliminating the option for trim-to-fit)
I looked outside the box too....to brands less obvious....Flex-a-lite, Durale, and even the new brushless models.
I've compared their flow, amperage, static performance, and even tried to correlate CFM to MPH. That's because the real goal is to duplicate what your car does "at speed" so cooling continues just as successfully at a stop. And, it might be possible for the average person to drive (at lower speeds until they find the MPH/CFM necessary to meet a personal goal.
Again, mine was to stay below 200-deg. This thread contains a timing table AND a link that shows why that can be an advantage. Modified setups (like my higher compression stroker) raise the heat-load over stock.
When people think of modifying a motor, often they might not consider transmission/differential "impact". The more I looked at this issue, the more I think cooling should be as important a consideration as transmission, rear-end, and tuning. At the very least, there's a lot to think about which made me think this forum needed a place to consolidate it.
I think what's posted so far has good interest on the topic. I hope even more practical things you can check/do will be presented. I like that a late model radiator swap thread is being circulated. I was thinking of starting another (with pictures of mine) for how older radiators are removed. With all of the extra things I've already thrown into this thread, maybe the word "fan" should be removed from the title?
An examples (specific models) you'd like to share? I think people would really be interested in specific comparisons, specifications, etc....
For example, in my OP, I tried to compare fans by amperage/cfm. After my digging, it looks like dual 11" models outperform single 16" units. But, adapting the dual setup presents some challenges. The easiest one to adapt appears the less-likely to bump the best 16" model. (BTW...if you compare sq/in of the two options they are actually pretty close. I originally thought two 11" would be WAY better than 16's but I think anyone claiming 2700cfm per 11" fan is wrong.)
Something I read recently suggested 100CFM per amp was a good rule of thumb. To me, that fits. In looking at fans, a lot of people may notice FFDynamics advertises a 3600cfm unit. I've always doubted that claim because specs show it at 18 amps. IMO, that would put it below the SPAL options pulling 22, 24, or 26 amps. With that as a reasonable guideline, it's more likely to assume FFDs draw 1800cfm (or less) and are over-stated. If their ratings are that over-stated, I'd doubt their lifetime warranty claims too. Heck, I had trouble even contacting that company a couple years ago.
Apply that to radiators and you might suggest cooling ratings, longevity, price-per-whatever....or even a link to threads where people swapped from brand-x to brand-y and saw improvement.
Thanks,
Thanks,
This is the connector I would have expected on a cooling fan motor:
Here is the link from Autozone that says it fits my car.
http://www.autozone.com/cooling-heat...tor/129804_0_0
It also looks like you might [just] be able to crimp on a couple of female spade connectors and push those into the motor. If you wanted to get creative, you would coat the inside of the plug with grease/oil, wrap tape about the outside of the receptacle (to extend it), and "pour" in epoxy or fiberglass to mold your own plug. Might not come out (or work), but it's a creative option if you run into a brick wall.
Conversely, if you can find the right type of plug -- as far as spades and spacing -- but the receptacle is wrong, maybe you could cut away some/all of the outer receptacle wall(s) with a dremel.
Finally, there IS a website for VDO where they might be able to point you to the right plug (part#), vendor, or both. The website is www.usa.vdo.com
Thanks for the suggestions. I will post my results when I am successful in case somebody runs into the same issue.
Here is the link to Mid America Motorworks listing the AC Delco:
http://www.mamotorworks.com/Corvette...motor-617305-1
Update:
I purchased a CARQUEST fan motor, part # 35379, and everything is working finally. I did end up replacing one of the fan relays as well, but both fans work. I believe I also found my next project, while listening to the car idle, waiting for the temp to get high enough to trigger the fans, I noticed a rattle noise, I believe it is coming from the water pump. If so that would explain the fluid that drips under the car, I bet it has the original water pump and it's dying of old age.
