Backfire during Idle
Old Sep 15, 2016 | 03:44 AM
AngryVette's Avatar
AngryVette
1st Gear
Default Backfire during Idle
So i finished building my 86 vette when i came back from korea and after putting i wanna say 6-7k miles on it i know have a backfire that increases in noise during idle especially when driving. i replaced spark plugs and used a timing gun to make sure the timing was still right, but to no avail it is still backfiring. I miss my driving my vette so any advice would be much appreciated thanks.
p.s. ive been thinking maybe one of the sensors went out but im unsure on how i would test them
Old Sep 15, 2016 | 07:47 AM
antfarmer2's Avatar
antfarmer2
Triple check your spark plug wires. Did you use thermal grease on your ignition module?
Welcome to the forum.
Old Sep 15, 2016 | 08:15 AM
aklim's Avatar
aklim
You say you checked the timing but that depends on the harmonic balancer. Are you sure it isn't moving on you?
Old Sep 15, 2016 | 08:51 AM
Kevova's Avatar
Kevova
Backfire intake or exhaust? I would check rocker arm adjustment and for worn cam lobe. If you are using flat tappet cam it's possible for lobe to wear flat. A leak down test would show if valves are sealing against valve seats.
Old Sep 15, 2016 | 11:34 AM
383vett's Avatar
383vett
Do a leakdown test to see if you might have a bad exhaust valve or mechanical issue. Change plugs (again) and wires. If all ok, check injectors.
To Backfire during Idle
