Help: Fuel Injectors
Old Sep 17, 2016 | 05:55 PM
dsimon55's Avatar
dsimon55
Default Help: Fuel Injectors
Hi all
I have a stock 1985 coupe with the L98 350 engine.
I am having some issues with a couple of my injectors. If I take them out and hit on table, then put back my engine runs great. But soon after they clog up again.
So its time to change them.
I have a stock fuel system. So what size should I use? 22lbs?
How big can I go? Will going bigger help performance or just run richer?
Any one have any suggestions on brand?
Dave
Old Sep 17, 2016 | 06:37 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
hahaha. its a party with the 85's today. i just ordered a new set of injectors from john at fuel injector connection. here is a link to what you need to buy.
https://fuelinjectorconnection.com/c...esign-iii-24lb
when you fill out the order form, its asks you for your Chevrolet/Corvette/1985
he needs that to make them the right height.
there are vids on youtube that shows you the process. cheers. VT.
Originally Posted by dsimon55
Hi all
Dave
Old Sep 17, 2016 | 06:38 PM
Joe C's Avatar
Joe C
get yourself a set of bosch3's from Jon at FIC. good upgrade over original, first generation bosch injectors. BTW, originals are 24# and QUIT BANGING THEM ON THE TABLE!
bigger injectors is like over-carbing an engine - no performance gain, in fact, you may see a decrease in performance. stay with the stock sizing on a stock engine.
stock, iron head 85, you want 24# - no more, no less -
Old Sep 18, 2016 | 09:07 AM
dsimon55's Avatar
dsimon55
Old Sep 23, 2016 | 02:29 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
We have a sale going on today for the whole site. Enter "tgifriday" and get 10% off your order at www.fuelinjectorconnection.com!
Old Sep 23, 2016 | 02:38 PM
antfarmer2's Avatar
antfarmer2
Jon is a good man he will take take of you.
Old Sep 23, 2016 | 03:32 PM
confab's Avatar
confab
85 vette here too. I got my bosch III from FIC also. Totally happy with them.
The delivery rating is different from stock because of the pressures they are calculated at, IIRC. 22# VS 24# or something? I've slept since then, but I know there was a difference.
Call them and they will get you the right set.
Old Sep 23, 2016 | 05:26 PM
tomcamaro97's Avatar
tomcamaro97
ide go with FIC!! i didnt but thats because i didnt need new ones but they were very helpfull.
I upped my injector #/hr and it was perfectly fine.. but ide buy stock.. theres really no reason to up your injectors unless your upping consumption..
You can always test yours by putting a stethascope on the injector and if you dont hear the "ticking" while runnning/cranking they arent working.
Also, maybe disconnect your fuel rail and key on your engine.. make sure your not getting debris in your fuel line thats clogging your injectors.. you dont wanna clog up your new set once you get it.
Old Oct 1, 2016 | 02:17 PM
Red1990VT's Avatar
Red1990VT
For what its worth, and I know this is controversial, I went with the Delphi OEM fuel injectors for my 1990 recently. The original factory injectors lasted 26 years and 90K miles, and the existing system, computer, PROM, exhaust, and so on were designed to use them. Aftermarket injectors may have the same pounds rating, but a different curve ("transfer function") than the OEMs. Probably not a big deal, but again, the car was designed to run with the OEMs, why not just use those? My two cents, and I've been very happy since doing the replacement on my 90.
Old Oct 2, 2016 | 08:00 AM
aklim's Avatar
aklim
Hi all
Dave
I really don't recommend hitting injectors to get them to function. Not sure what is going on there. How did you know they clog up? Should not since there is a filter there unless you have way more fine crud in the tank than you should. That or the filter basket is clogged and you are shifting it around with knocking and it settles back down.
You can go bigger but it won't help. ECM will see it and dial the pulse width back down. Stock replacement from FIC will help. Generally, I would say a pound or two at stock pressure won't make a difference but if I put in my 42pph injectors in your car, I promise you it will flood since you don't have the adjustment in the ECM.
Give Jon a call and he will help you select what is best unless you have a tuner that set your ECM for something different. After which, I'd send it out every few years for cleaning and testing.
Old Oct 2, 2016 | 08:04 AM
aklim's Avatar
aklim
Those were designed around 100% gasoline and became an issue with Ethanol.
I'm not sure how different the curve can be when you have a set poundage, pressure and pulse width but the ECM can adapt unless it gets too radical so why pay more for OEM?
To Help: Fuel Injectors
