Fuel pump pickup
Old Sep 16, 2002 | 01:57 PM
buzzbomb's Avatar
buzzbomb
Default Fuel pump pickup
'84 vette, has the same problem as lots of people seem to have, cuts out on hard corners when fuel is low. What do I need to look at on the pickup end? What can be serviced, and what needs to be replaced exactly. Also the big question, what does it cost and where do I send my money to! TIA :smash:
Old Sep 16, 2002 | 02:02 PM
vettmech's Avatar
vettmech
Default Re: Fuel pump pickup (buzzbomb)
BUZZBOMB , I think you are having a problem similar to several of us on here today. YOU may also have a loose baffle in the tank......... :seeya
Old Sep 16, 2002 | 02:09 PM
buzzbomb's Avatar
buzzbomb
Default Re: Fuel pump pickup (vettmech)
Is this obvious when you take off the top of the tank? Can it be wired in place somehow?
Old Sep 16, 2002 | 02:19 PM
vettmech's Avatar
vettmech
When you pull the pump and guage assy out you will be able to reach it. it's at the bottom of the tank. It's glued in place (I think) but I have no idea of what kind of glue. I don't see how it could be wired in place either ........ I would sure try it if it were possible......... :seeya
Old Sep 16, 2002 | 02:50 PM
Sharky Guam's Avatar
Sharky Guam
It is epoxied in place. You could re epoxy it.
Old Sep 16, 2002 | 02:51 PM
scorp508's Avatar
scorp508
In over 2 years on the forum I have never heard of the baffel coming loose for anyone until this week. I would look elsewhere first. Not that it isn't a possibilty, but I would rule out the more common issues first.
To Fuel pump pickup
