Air flow
Old Oct 26, 2016 | 10:37 AM
Billygoatkid's Avatar
Billygoatkid
Default Air flow
hey,
so I've been doing some tuning and been pretty successful .
my question is: gms, I'm only hitting about 205. Is this normal?
i don't use all the mass air flow tables .
1988 , headers ported plenum 1.6 rocker, 3.54 rear
thx
Old Oct 26, 2016 | 10:55 AM
antfarmer2's Avatar
antfarmer2
On the digital temp gauge if you have one? Analogs lie my 94 runs under 200 on the freeway and the fans start at 225. They do run hotter than most. I pulled my radiator and cleaned it when mine was over 200.
Old Oct 26, 2016 | 11:18 AM
bjankuski's Avatar
bjankuski
Originally Posted by Billygoatkid
hey,
thx
This is in reference to 205 grams/sec on the MAF when you are data logging correct? That should be normal, you will not hit 254 gr/sec until you have mods that are near 350 HP.
Old Oct 26, 2016 | 11:24 AM
antfarmer2's Avatar
antfarmer2
My bad.
Old Oct 26, 2016 | 11:34 AM
Billygoatkid
Thx
just thought it should read higher , pretty sure it has a cam the way it idles and pulls.
Old Oct 26, 2016 | 11:45 AM
bjankuski's Avatar
bjankuski
Thx
It is good that it does not read much higher because it allows you to do additional modifications before the MAF hits the max reading of 254 gm/sec and then the tuning becomes less consistent.
Old Oct 26, 2016 | 12:44 PM
tequilaboy's Avatar
tequilaboy
205 gm/sec peak air flow sounds about right for the listed mods...maybe 230-240 rwhp.
However, if you have edited the MAF tables while tuning, you have changed the MAF calibration, so all bets are off with respect to accuracy.
With original tuning 206 gm/sec is 4.39 volts.
You can use your WBO2 to recalibrate the MAF so that the WBO2 matches the target AFR with neutral fuel trims (assuming the injector settings and fuel pressure are also correct).
To do this efficiently, you need to include your WBO2 0-5 v output into the data stream so that signals can be logged simultaneously.
Old Oct 26, 2016 | 01:03 PM
Billygoatkid
I have adjusted the maf tables. Lots .
Im listening and very interested in adding the wideband signal ,
im using tuner pro and data master .
my wideband has an output for it , just don't know where to hook up
thx
To Air flow
