Same old problem
Old Nov 5, 2016 | 12:36 PM
aklim's Avatar
aklim
Originally Posted by mlm0
does not get worse with humidity as far as I can tell
how do you do power balance test?
Relative humidity is the moisture off your sister's back as you are getting it on. OK seriously, increase humidity. Sprayer set to fine mist around the wires in a dark garage works.
Pulled one injector at a time. Each should make the motor run worse. If it does, put it back and proceed to the next one. If one influenced the motor less than the others, you have a starting point
Old Nov 5, 2016 | 02:04 PM
mlm0's Avatar
mlm0
thanks. Will try that this week. I'm talking about connectors only 👍
Old Nov 5, 2016 | 03:43 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
by slight miss do you mean a slightly rough idle?
i had two recent situations that gave me the type of misfire rough idle.
The first instance was on my 85, there was an injector wire broken. This does not throw a code and has nothing to do with the injector. You can test your injectors to make sure they are all firing with a noid light set. my said cost me $20, and I never in 1 million years would've thought that I would've ever had to use it to fix a problem. But there I was a year after about it and I discovered that I had one cylinder that was not firing because the injector was not firing. The injector itself was fine.
https://www.corvetteforum.com/forums/c4-tech-performance/3879174-i-have-one-very-quet-injector.html
The second instance I just had and I was getting a miss as I was driving down the road and the car was jerking or trailer hitching or fish biting. At idle it sounded the same almost as when I had a non-firing injector.
https://www.corvetteforum.com/forums/c4-tech-performance/3899042-fish-biting-jerkiness-hesitating-barking-1987-going-through-the-checklists.html
i also had a third instance where the coil was not pushing out the power it should. the only way i was able to diagnose this one was to do this crazy test:
but it did work 100%. i discovered my spark wS mediochre to not present. when i swap in a spare coil i had, i got a nice food spark.
it could also have been the ignition module.
in the case of fuel, if you have a fuel pressure gauge you would see either irratic pressure or low pressure when u got your symptims.
Old Nov 5, 2016 | 03:53 PM
mlm0's Avatar
mlm0
How do you use nous lights Do you have to pull connector off of injector to use it
Replaced coil and module already
QUOTE=VikingTrad3r;1593403101]by slight miss do you mean a slightly rough idle?
in the case of fuel, if you have a fuel pressure gauge you would see either irratic pressure or low pressure when u got your symptims.[/QUOTE]
Old Nov 5, 2016 | 05:25 PM
mlm0's Avatar
mlm0
Originally Posted by mlm0;159340 pull connector off o
replaced coil and module already
quote=vikingtrad3r;1593403101
I had two recent situations that gave me the type of misfire rough idle.
The first instance was on my 85, there was an injector wire broken. This does not throw a code and has nothing to do with the injector. You can test your injectors to make sure they are all firing with a noid light set. My said cost me $20, and i never in 1 million years would've thought that i would've ever had to use it to fix a problem. But there i was a year after about it and i discovered that i had one cylinder that was not firing because the injector was not firing. The injector itself was fine.
Http://www.corvetteforum.com/forums/c4-tech-performance/3879174-i-have-one-very-quet-injector.html
the second instance i just had and i was getting a miss as i was driving down the road and the car was jerking or trailer hitching or fish biting. At idle it sounded the same almost as when i had a non-firing injector.
Http://www.corvetteforum.com/forums/c4-tech-performance/3899042-fish-biting-jerkiness-hesitating-barking-1987-going-through-the-checklists.html
i also had a third instance where the coil was not pushing out the power it should. The only way i was able to diagnose this one was to do this crazy test:
But it did work 100%. I discovered my spark ws mediochre to not present. When i swap in a spare coil i had, i got a nice food spark.
It could also have been the ignition module.
In the case of fuel, if you have a fuel pressure gauge you would see either irratic pressure or low pressure when u got your symptims.
[/quote]
Old Nov 5, 2016 | 05:28 PM
mlm0's Avatar
mlm0
Never mind. I watched video on how to use mood lights
Old Nov 5, 2016 | 05:37 PM
VikingTrad3r
Oil Producer
noid lights super easy. simply unplug connector from injector and plug in the noid light. do it while running.
here is my dizzy test vid i forgot to link to:
it looks complicated but very easy.
https://youtu.be/rc9b0prqzKs
Old Nov 5, 2016 | 08:16 PM
confab's Avatar
confab
What are you doing there exactly?
Old Nov 5, 2016 | 10:01 PM
VikingTrad3r
Oil Producer
testing spark.
my bad coil generated a weak spark every 10th or so rotation.
my vid and this vid is what you should have.
i tried the "coil test" using resistence values but mine showed it was good using that test.
but no spark!!!!!
https://youtu.be/F2yEu1g5trw
Old Nov 7, 2016 | 02:59 PM
confab's Avatar
confab
testing spark.
but no spark!!!!!
Well, that is pretty innovative.
