Same old problem
Old Nov 4, 2016 | 04:16 PM
mlm0's Avatar
mlm0
Default Same old problem
1989 with auto trans, 51000 miles, no mods, except no egr or air pump or cats
bought this car 4 years ago. My second 89.
I have been working on this problem from the first day I bought it
at idle it has a slight misfire. It has no pattern and I can't figure which cylinder or cylinders is causing the problem
i worked it as though it was vacuum leak, but I can find none. I used sprays, smoke and plugged off everything, but it's still there
i have replaced or adjusted everything that I can think off. I replaced head gaskets and heads redone because of number 7 blown.
When i I say this, I am serious, the only part I can think of that I have not replaced is the distributor itself and the brake master cylinder I have extra distributor just haven't changed it out yet
numerous time I thought I had it fixed, just to discover I had not
if you were to check all my postings, you would see what I have done to try to fix this problem
can anyone one help me?
Old Nov 4, 2016 | 04:21 PM
bjankuski's Avatar
bjankuski
Have you checked or replaced the injectors?
Old Nov 4, 2016 | 04:32 PM
mlm0's Avatar
mlm0
Yes, replaced with boush 3 four years ago and had then rebuilt 5 months ago by FIC
also replaced FI connectors
thanks for reply
Old Nov 4, 2016 | 05:41 PM
Carvet's Avatar
Carvet
Happened to me about 10 years ago. It was my fuel pump.
Old Nov 4, 2016 | 05:45 PM
confab's Avatar
confab
IAC hunting around?
Old Nov 4, 2016 | 06:45 PM
mlm0's Avatar
mlm0
Interesting, I have replaced it, but I have noticed that my dash lights kinda dim at idle. I wonder if I am not getting enough voltage at idle. My output voltage on dash reads ok but guess I could have a bad ground
Old Nov 4, 2016 | 06:47 PM
mlm0's Avatar
mlm0
[QUOTE=confab;1593398304]IAC hunting around?[/QUOTE
my mt-2500 shows iac staying steady at 29
Old Nov 4, 2016 | 07:02 PM
mlm0's Avatar
mlm0
I forgot to mention that the longer I set at a light idling, the worst it seems to get. When I first stop, it's not bad at all
Old Nov 4, 2016 | 07:41 PM
aklim's Avatar
aklim
IF the injectors are good, maybe we can start looking at spark? Your IAC holds at 29 so it doesn't look like an air leak. In the garage, do you have a blue flame? How are the wires? Have you checked them for leakage?
Old Nov 4, 2016 | 08:21 PM
mlm0's Avatar
mlm0
replaced plugs and wires two times. Checked in the dark garage, and thought I saw a spark jump, so I replaced them first time. No difference
anyone know the best way to see if the voltage is correct and consistent at fuel pump at idle?
could a worn distributor shaft or gear cause this problem?
Old Nov 4, 2016 | 08:28 PM
aklim's Avatar
aklim
Fair enough. What did you replace them with? Decent quality or some "backdoor special" at the local parts house?
I think my scanner tells you the fuel pump voltage. Not sure if it is accurate or not but you can hook up a DVOM to the pump at the back. It is pretty easy to remove. Thing is I would check pressure since it is the easiest. If the pressure is good, not sure I would go further. Check WOT and see.
I would check the shaft as it sits for play. If I had to remove it, I would take it out but mark it first for easy install. Make sure you don't bump the engine or you will have to time it all over again. Have a trusted couple of people check it out.
Old Nov 4, 2016 | 08:49 PM
mlm0's Avatar
mlm0
replaced with good parts. My scanner also shows good voltage, but I don't know where that reading is taken from. I will tape pressure gauge to window to check pressure
i have checked vacuum and it shows about 18, but does bounce lower just barely, in time with misfire
Old Nov 4, 2016 | 08:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Video of the symptom? That might help...
Old Nov 4, 2016 | 09:14 PM
jv9999's Avatar
jv9999
One of the terminals on the ALDL connector is for measuring fuel pump voltage. Have you measured fuel pump pressure at idle? What chip is in the ECM? Is it stock? Try taking an inductive pickup timing light and putting it on the plug wires one at a time. Watch the flash for 30 seconds or so. See if it misses.
Old Nov 4, 2016 | 09:15 PM
mlm0's Avatar
mlm0
i don't think a video would help. You really can't hear it or see it. I can feel it setting in the driver seat
Old Nov 4, 2016 | 09:43 PM
mlm0's Avatar
mlm0
i will try timing light
stock chip
Old Nov 5, 2016 | 12:25 AM
Cliff Harris's Avatar
Cliff Harris
You can measure the fuel pump voltage at the FP fuse.
To Same old problem
Old Nov 5, 2016 | 01:24 AM
wikdwizard's Avatar
wikdwizard
Have you done a "power balance" test to try narrowing it down to a specific cylinder? Your description of the inconsistent vacuum with the idle drop makes my brain say valvetrain instability, usually in the form of a valvespring failure.
Ignition is still a possibilty.......does the symptom get worse with humidity?
Old Nov 5, 2016 | 02:57 AM
2airtime2's Avatar
2airtime2
Monitor the voltage with a digital vom. Duplicate the problem in the driveway and connect jumper cables from a running vehicle and see if the problem goes away. If compression is good I think whoever mentioned voltage is on to something. Luckily that's easily verified.
Old Nov 5, 2016 | 11:58 AM
mlm0's Avatar
mlm0
does not get worse with humidity as far as I can tell
how do you do power balance test?
