cam quest
Old Sep 18, 2002 | 04:37 PM
DADDY D's Avatar
DADDY D
Default cam quest
is there a problem with the computer if your cam is too big and if so what size does anyone know
Old Sep 18, 2002 | 05:04 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: cam quest (DADDY D)
The stock computer is pretty good about making the car "run" with anything you throw at it. Sure it'll lope around and overall sound pretty nasty, but it will eventually learn how to make it idle and such.
The problem is with the rev limiter and WOT tuning. At part throttle the computer will try to correct to the proper A/F ratio within it's range of adjustment, so that's usually alright.
There isn't a magic cam size in which the computer won't let it run, there are too many variables. With a very mild cam you might not need to change anything, but the more aggresive the cam the more you need tuning to take full advantage of it.
Old Sep 18, 2002 | 05:05 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
It may depend on the year of the computer and whether or not the car is a MAF car or not. In my '94 I had no problems running a really big cam as far as the computer was concerned.
Old Sep 18, 2002 | 05:27 PM
DADDY D's Avatar
DADDY D
Default Re: cam quest (Vette92)
we are talking about an 86 is there a way to bypass or remove ther rev limiter..
Old Sep 18, 2002 | 05:29 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
You can have a chip burnt to remove the rev limiter. Look for Craig Marcho, I think he goes by Marcho Polo on the Forum.
Old Sep 18, 2002 | 05:49 PM
vader86's Avatar
vader86
86's dont have rev limiters, GM made it like 10,000 because they knew the TPI would stop you well before you even got to 7000-8000rpm
The car will run, but you wont make near as much power without tuning.
Old Sep 18, 2002 | 06:38 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: cam quest (vader86)
Interesting. I did not know that.
Old Sep 19, 2002 | 06:06 PM
DADDY D's Avatar
DADDY D
thanks
Old Sep 20, 2002 | 01:53 AM
Kendall's Avatar
Kendall
Crane makes a line of cams made to work with the computer. What they do is give you lots of lift without a whole lot of extra duration. The theory is you don't want to get the lumpity lump idle because the computer will see no vacume and not know how to act. Crane recommended the hottest cam for me since I was building a 383. I'm going to change it out because it is a total dog until I hit 2000 rpm. Part of my reasoning to go 383 was to get that extra bit of thrust at 1500. The next size down is supposed to get into the power band at 1500.
To cam quest
