fuel pressure
Old Sep 20, 2002 | 08:57 AM
Kendall's Avatar
Kendall
Default Re: feul pressure (atotalnincompoop)
It worked. They got your money!
Old Sep 20, 2002 | 09:25 AM
vettmech's Avatar
vettmech
Default Re: feul pressure (Bluevette85)
It is only supposed to hold full pressure for 5 mins. That what the GM test says......... if it holds longer great......... if it leaks after 5 mins they don't consider it a problem........ I don't know why. I have a guage on my engine and I open the hood at night when I park it....... it still usually has about 25 to 30 lbs after sitting overnight........ I also had at one time a split hose in the tank .......turns out I did that to myself when I changed the pump....... I didn't notice the hose was going bad on the inside........ lasted about a month then blew at 80 mph........... shut the engine OFF! :seeya
