Colliding Wiper Arms
Old Sep 19, 2002 | 05:10 PM
Ivory90's Avatar
Ivory90
Default Colliding Wiper Arms
Has anyone swapped out their early wiper arms and blades for the '96 arms/blades?
Did this tech tip resolve the collision?
Nothing is more unnerving than trying to regain normal heart rate after a wiper arm collision against the windshield. :eek:
Old Sep 19, 2002 | 05:13 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: Colliding Wiper Arms (Ivory90)
Yup, fixed it up nicely. The upgrade came out to I THINK $50. Five minute job. Contact Jeff Kopp (18carfan) :cheers:
BTW: my car is an 87
Old Sep 19, 2002 | 05:18 PM
Siveck's Avatar
Siveck
I did the upgrade on mine, but I also did some major adjusting, so I can't really say if it helped or not. The adjustment is rather easy, just remove either the left cowl cover or the little cover on the cowl above the wiper motor and loosen 10mm nuts to adjust. :)
Old Sep 19, 2002 | 05:26 PM
Ivory90's Avatar
Ivory90
Default Re: Colliding Wiper Arms (TIMSPEED)
I committed to the parts already...I must make note to self about Jeff.
Frank.
Old Sep 19, 2002 | 05:55 PM
Flame Red's Avatar
Flame Red
I seemed to solve this by replacing the driver's blade with an 18" rather than the standard 20". Never had that problem again.
Old Sep 19, 2002 | 06:54 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: Colliding Wiper Arms (Flame Red)
Old Sep 20, 2002 | 10:45 AM
Frodo's Avatar
Frodo
Default Re: Colliding Wiper Arms (lead foot 85 vet)
My wipers nipped a little as they passed. I found the previous owner had put 21" wipers on instead of the 20s. The correct wipers work fine now. I do have wear in the motor/actuator assembly and may have to r&r the works at a later date. What's the scoop on using later wiper arms and blades?
:flag
Old Sep 20, 2002 | 06:47 PM
Ivory90's Avatar
Ivory90
Default Re: Colliding Wiper Arms (Frodo)
I'm the original owner. I replaced the wiper blades several years ago instead of going with the GM refill.
I'm gonna do the later model swap, see what that does for me and then try not to think of all the good money thrown down the drain on impulsive purchases for my Ivory90.
:mad
Old Sep 20, 2002 | 06:53 PM
Siveck's Avatar
Siveck
The angle of the blade attachment head is altered on the right side so that when parked, it (top one) will sit parallel to the windshield. This also moves the blade away from the right side frame when the wiper goes up. The springs in both arms are supposedly lighter to eliminate chatter.
Old Sep 20, 2002 | 09:48 PM
1987vette's Avatar
1987vette
Had that problem 2 years ago - I'd adjust the arms and it worked fine -till it would rain - finally found the problem - the nut on the motor would slip just a touch ( it was tight but not tight enough) - haven't had the problem again :D
Old Sep 21, 2002 | 01:25 PM
FSTRNU's Avatar
FSTRNU
Default Re: Colliding Wiper Arms (1987vette)
Took mine to the dealer cause I didnt want to mess with it and break my windshield.
Old Sep 30, 2002 | 08:08 PM
Ivory90's Avatar
Ivory90
Default Re: Colliding Wiper Arms (FSTRNU)
I'm still awaiting one of the wiper arms from my dealer order.
I can't wait to slap them on.
Old Sep 30, 2002 | 11:41 PM
92TripleBlack's Avatar
92TripleBlack
That's what I did. Why go to a dealer? Its 30 seconds with a flathead screw driver to pry open the clip. That's it. Easier than changing the air filter. :rolleyes:
To Colliding Wiper Arms
