C4 rev limit
Old Dec 28, 2016 | 05:56 PM
Rodney Lux's Avatar
Rodney Lux
1st Gear
Default C4 rev limit
What is the highest rpm you can run a c4 at safely?
Old Dec 28, 2016 | 05:58 PM
MatthewMiller's Avatar
MatthewMiller
A C4 with what engine? An LT4 is factory redlined at 6400rpm. ZR1s are probably higher than that. But L98s might not even be capable of reaching that speed, and definitely wouldn't be safe there!
Old Dec 28, 2016 | 06:11 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
IIRC, L98's redline somewhere in the 5k-5200rpm range. LT1's redline at 5800rpms. I suspect the only limitation to the LTx cars relate to the rotating assembly. By contrast, the longer-tubed L98 intakes actually create negative pressure on the rods. That's because they can't pull air fast enough above redline...which means they are being "held back". This creates undue "counterforce" on the pistons/rods.
Also, I'm thinking the rev limiters in each would allow the engine to spin higher than redline -- though you really wouldn't want to do it for long.
Old Dec 28, 2016 | 06:20 PM
MatthewMiller
I know the LT4s have different valve springs and lighter valves, too. Those may have been offset by the more aggressive cam lobes, though. They did also have 4-bolt mains as well, so it's hard to isolate one key change.
Good point, and I must correct my last post. The PCM rev limiter on an LT4 is set at 6400rpm, but the official redline was actually 6300rpm.
Old Dec 28, 2016 | 06:33 PM
bjankuski's Avatar
bjankuski
There is no rpm limit on the L98 in the computer, mechanically it can hande 6000 rpm but it will not make any power at that rpm. Shift a l98 by 4700 rpm for best performance, lt1 by 5600 rpm for best performance, and a LT4 by 6000 for best performance.
Old Dec 28, 2016 | 09:21 PM
Lt4-396's Avatar
Lt4-396
Also all corvettes ltx motors had 4 bolt mains, it was not lt4 specific.
I've spun my lt4 up to 6500-6600 and didn't hit a Rev limiter unless the tach is slightly off.
Old Dec 28, 2016 | 09:25 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
In my '87 owner's manual it states there is a fuel cutoff at 5600 rpm.
In my '96 owner's manual it states there is a fuel cutoff at 5850 rpm for the LT1 and 6400 rpm for the LT4.
Old Dec 28, 2016 | 09:38 PM
MatthewMiller
Well I'm full of all kinds of misinformation today! Thanks for correcting that.
The stock programming is set to cut off fuel at 6411rpm and resume fuel delivery at 6397rpm, to be ridiculously specific. That's per Jet DST programming software, as read from the OE calibration I downloaded. I have noticed a similar thing, though, re the tach on the dash. I think it's just a little optimistic.
Old Dec 28, 2016 | 10:21 PM
bjankuski's Avatar
bjankuski
There is no rev limit or fuel cutoff in a l98, the manual is wrong or referencing something else. I have looked at 100's of chips, no rev limit.
Old Dec 28, 2016 | 10:54 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Stock LT5 is 7200rpms
Old Dec 28, 2016 | 11:04 PM
MatthewMiller
Not true! Chevy clearly doesn't want you to exceed 10,000rpms in your L98!
Old Dec 29, 2016 | 11:46 AM
vader86's Avatar
vader86
Correct the L98 uses a fuel cutoff set at 10,000 rpm, which it will never ever reach. It does not have a true rev limiter (which cuts spark).
Old Dec 29, 2016 | 11:57 AM
MatthewMiller
Even my LT4 doesn't have a spark cutoff. Like the L98, it just uses a fuel cutoff, but it is actually set at a useful speed. It's interesting that years before, GM had ECMs with capabilities that they didn't actually use until much later.
Old Dec 30, 2016 | 12:18 AM
bjankuski's Avatar
bjankuski
I was always curious why they did not use the rev limiter in the L98 program, set it at 6000 RPM and forget about it?
Old Dec 30, 2016 | 12:24 AM
bjankuski's Avatar
bjankuski
Factory uses the fuel cut as the rev limiter on their cars so they do not load the exhaust up with air and fuel and then light it off when the ignition comes back on. That can make for some really ugly exhaust explosions.
Some of the newer drive by wire cars limit the RPM by closing the throttle at the rev limit.
Old Dec 30, 2016 | 12:47 AM
MatthewMiller
Good point. It would probably also play hell with catalytic converters, too.
Old Dec 30, 2016 | 02:46 AM
DMITTZ's Avatar
DMITTZ
I know as others have stated that the L-98 has a 'rev limiter' set at 10,000 RPM (which is useless!) from the factory. No idea why it was not set at a reasonable RPM.
However, if you are getting your prom 'burned'/programed you can have your tuner set the Fuel cutoff/rev limiter at what ever you want. I just got a new tune and had mine set at 5,600 RPM to keep me from accidentally ever over-reving my engine.
To C4 rev limit
