Need help with Crank/No Start condition
one thing I did find was that the coil power leads were rotted and thinned at the ICM and the Coil connections, while you are looking for your Cause just give a good look at your Wiring. Sometimes we Forget what could be Staring at us.
That is a good idea too. I replaced the corroded harness to the opti and replaced the coil pigtail too. I now have an ICM pigtail I can switch out too.
Anybody have any suggestions for what I should check before I put all this back together?
Well mine were Auto Zone I went though I think 5 or 6 of them. a friend of mine has a MSD that he took out of a wrecked LT-1 car so I will be installing it when it gets here Hopefully it fits/works .
My last A-Z opti had a odd problem I installed it did a test start before fully assembling car kicked right off smooth. Shut right off finished the assemble, Poured in a Gal. plus bled off the the trapped air started and kept adding the coolant to top off.
But when the car hit 155 deg F shut off NO SPARK, NO INJ. Pulse. rechecked everything, Car started hit 160 Coolant Bam shut down. I had a good ICM & Coil so I plugged them in car started again it Died around 160/175 I was thankful that there is someone else chasing a problem and that hit me and made feel better just pulling and handing back the just installed Opti.
https://www.corvetteforum.com/forums...post1580563535
Should i replace it and try again with a new opti? What brand do you recommend?
Video link:
any advice appreciated!
I have been trying to learn about grounds today.
I checked resistances and voltages with my multimeter with the key on:
engine (intake manifold or ICM ground) to negative battery terminal = 1.3 ohms (no voltage)
chassis to negative battery terminal = 4.3 ohms (no voltage)
engine to chassis = 3.3 ohms (no voltage)
Edit: I have just read that the battery can cause false resistance readings, so with the key off all resistances were 0.2.
PCM ground connectors to negative battery have no resistance.
If anyone can link me to a thread or video that would help me do this, I would appreciate it. I'm doing my best to find the answers. I am trying to believe this is not an optispark problem because it seems like the SacCity model has been good for many. However, following this thread http://www.mainstreamtopics.com/foru...rt-diagnostic/ it is still a problem with the optispark.
