Lug Nuts
Old Jan 30, 2017 | 07:46 AM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
Default Lug Nuts
I recently purchased an 88 Anniversary Edition with the white aluminum wheels. Several lug nuts were either missing or stripped and the nuts that are on do not appear to be correct. Searching several sites show many different lug nuts. Need help on correct style. Attached is picture of current nuts.
Old Jan 30, 2017 | 08:01 AM
WVZR-1's Avatar
WVZR-1
I believe just a M19 hex with the correct bulge. Use this OE for a Dorman correct on nearly every auto parts shelf, GM# 14092873
*** I wouldn't be hurried to buy matching! So long as you've got proper bulge and a M19 hex who cares. You've a cap to cover them!! If they fit and ain't stripped - don't worry.
Old Jan 30, 2017 | 08:18 AM
Joe C's Avatar
Joe C
as WVZR-1 says...
since you have anniversary wheels, the lug nuts will not have external threads as shown in your pic. , the original GM OE part number for the lug nuts is 14092873. a suitable replacement (M19-B) is available at rockauto, or just about any parts supplier -
http://www.rockauto.com/en/moreinfo....041242&jsn=529
Old Jan 30, 2017 | 09:07 AM
cdm747's Avatar
cdm747
Originally Posted by Joe C
as WVZR-1 says...
I bought some at NAPA. Just wasn't sure because they go in a lot further. When fully tightened there is only about a 1/4" of lug still protruding. They appear to be the same as the ones shown at rock auto.
Old Jan 30, 2017 | 10:50 AM
c4cruiser's Avatar
c4cruiser
The lug nuts in the pic are a type that GM used for a wide variety of passenger cars that used a plastic cap over those nuts. That's why there are external threads on them.
With the wheels using a center cap covering the area, just get a set of bulge-style lug nuts with a 60 degree taper. Your existing lug nuts will work fine assuming there is no interference with the center caps.
Old Jan 30, 2017 | 11:14 AM
mixalive's Avatar
mixalive
I would think you would want the 5 lugs per wheel to weigh the same.
Old Jan 30, 2017 | 01:15 PM
383vett's Avatar
383vett
Originally Posted by cdm747
Something seems wrong with this picture. The stock lugnuts, being a cone seat and not a shank, will only grab a few threads of the studs. That is why some have stripped. Either the studs are too short or the wheel is too thick. This car would not pass tech at a NHRA sanctioned strip; the threaded stud has to protrude past the lug nut, and is actually dangerous to drive.
Old Jan 30, 2017 | 01:38 PM
cdm747's Avatar
cdm747
I didn't like the way they looked either. I will post a picture of the newer ones I installed when I get home later.
Old Jan 30, 2017 | 01:49 PM
pifo1964's Avatar
pifo1964
https://www.amazon.com/DPAccessories...+Wheel+Lug+Nut
I bought these for my car to replace the 4 safety nuts and I have the rest for backup. They are identical to the OE, they are 20 and also have the external thread, but I´m not sure if your 88 is the same as my 93
Old Jan 30, 2017 | 07:58 PM
cdm747's Avatar
cdm747
OK - I just figured out that the ones NAPA sold me are the standard lugs and not the bulge type. That is why they go in so far. I just ordered a set of the Dorman 611063.
Old Jan 30, 2017 | 08:10 PM
WVZR-1's Avatar
WVZR-1
I'm with this guy and there's certainly apparently issues with the stud length.
OP- pull a wheel and measure from the rotor to the tip of the stud. You might maybe just check all of the wheels and maybe it's just unique to the one you chose to take the snapshot of. The studs certainly seem very short.
I can't compare to any of mine because everything I have has the dog-point.
Old Jan 31, 2017 | 08:29 AM
cdm747's Avatar
cdm747
I just checked the Rock Auto web site for the stud. It shows a M12x1.5 stud that is 41.5mm long. That is approximately 1 5/8". I will check when I get home later but I am pretty sure that is what is on the car.
Old Jan 31, 2017 | 10:34 AM
383vett's Avatar
383vett
Maybe the previous owner put a spacer behind the wheel.
Old Jan 31, 2017 | 11:10 AM
cdm747's Avatar
cdm747
I removed all four wheels from the car to replace the broken and stripped studs. There were no spacers behind the wheels. The standard (no budge) nuts do go on to give a full nut but when I replace them with the budge type that I ordered they probably will not. The only other option would be to replace all of the studs with longer ones. I can't believe that all of the studs have been replaced with incorrect ones but I guess anything is possible. That is why I started this thread in the first place.
Old Jan 31, 2017 | 11:11 AM
WVZR-1's Avatar
WVZR-1
I thought early studs less the dog-point were near flush with correct nuts (less external threads) and actually the nut with external provisions wasn't threaded to the end so might present itself as recessed but would be considered acceptable.
I've not had one of the bulge less the external threads in hand for a long while but I don't remember them being only partially threaded. The external threaded that isn't threaded to the end will do NHRA I believe if they look and see that there's no threads in the bore. I believe I recall a situation similar with a Fiero of a friends.
To Lug Nuts
