least restrictive??
Old Jan 30, 2017 | 08:15 PM
craneman61!'s Avatar
craneman61!
Default least restrictive??
Having to replace cats on 1996 LT1. Trying to decide between flow master hi flow and magnaflow hi flow. Does anyone know which would be better? I have searched for specs on both but haven't found any information. Also will be replacing exhaust with either OBX or Allens chambered exhaust. Any info and opinions will be really appreciated.
THANKS TO ALL
Old Jan 30, 2017 | 08:37 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Old Jan 31, 2017 | 03:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
interesting the old 40 series flows are a little more than 1/2 of the ultraflow
OP a straight through muff will have the least amount.
Personal choice. Although they look abtou the same inside i Hate the way magnaflows sound. Like a boat..or a RAm truck
Ultraflows esp with some overlap and a tight lsa on WOT my god there is nothing sweeter youll want to romp on it over and over and over.
Ovals a little quieter and high pitched than the welded. Kick azz pieces.
Old Jan 31, 2017 | 03:11 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yep. Flowmaster's don't do that well. How could they? Look inside the things.
Old Jan 31, 2017 | 03:13 PM
aklim's Avatar
aklim
I'd be curious how Corsa flows since it is supposedly quiet and that is what I will get if my current Borla Stinger gets damaged
Old Jan 31, 2017 | 04:30 PM
Silver85's Avatar
Silver85
Any charts showing the CFM flow of a 350?
Old Jan 31, 2017 | 04:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
A 350 what....engine? What state of modification? Need more info.
Don't need a chart for though: 350CID/2 (b/c it's a 4 stroke)=175 * RPM (let's use 5000)= 875,000/1728 (to convert CID to Cu Ft)= 506.3 CFM. But wait, that is 100% VE which most of us don't reach. So, 506*(VE).8= 405CFM. The exhaust only needs to be ~70% of the intake, so 405 * .7 = 283 CFM...let's say 300 CFM.
Old Jan 31, 2017 | 06:29 PM
Silver85's Avatar
Silver85
Ha! Perfect!
stupid question, but what does VE stand for?
Old Jan 31, 2017 | 06:39 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Silver85
Ha! Perfect!
Volumetric Efficiency. An engine with heads, cam, great exhaust and intake would have higher VE.
Old Jan 31, 2017 | 06:41 PM
Silver85's Avatar
Silver85
So you're saying the cylinders are still in negative pressure when the compression stroke begins? But if we had a bigger intake bigger valves Etc we will be able to lessen this?
Old Jan 31, 2017 | 11:48 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yes and yes. That is why modding an engine helps; you're improving the pumping efficiency of the engine. Same size engine, but it makes more power. How? More air in, more cylinder pressure, more exhaust out.
Old Feb 1, 2017 | 08:53 AM
Silver85's Avatar
Silver85
So, based on the chart, having two stock mufflers rated at 252 CFM would provide no restrictions to the exhaust flow? I would guess these ratings were made at a certain static pressure.
I wonder if the manifolds have any numbers associated for flow rates? One of the few mods I was considering for performance was a set of headers. I would be curious as to the flow rates of each brand and at what point they reach the rate of diminishing returns.
Old Feb 2, 2017 | 02:14 PM
Magna_Flow's Avatar
0Magna_Flow
Former Vendor
Hi Craneman, we offer a few 49-state legal cat replacement options that are much more affordable than OE units. Our universal cats (#99006HM) can be welded on by your local exhaust shop, and our direct fit cats (#23408 and 23409) replace the entire section of piping so no modification is required.
If you were looking for more sound from your exhaust, we also offer a Street axleback #15623 that will bring the deep muscle car sound out of your Corvette.
http://www.magnaflow.com/products?partNumber=15623
If you have questions about any of these products, drop us a PM anytime!
To least restrictive??
