air pump removal
Old Feb 2, 2017 | 12:09 PM
acer50548's Avatar
acer50548
6th Gear
Default air pump removal
anyone have advise on removal of the airpump on my 89? what needs to be changed out regarding the chip? any advise about after market chips that can be used and programed? novice about chips.
main concern is what removing the dual valve attached to 2 of the air pump hoses and what will the current chip do if this is disconnected.
any help or advise on where to go or who to talk to.
id like to next change out intake runners, add ceramic headers and go to a 2.5 exhaust. see if this will add some torque and better sounding exhaust.
thanks on any advise about whole project.
steve
Old Feb 2, 2017 | 01:58 PM
vader86's Avatar
vader86
Removal of the AIR system does not throw a code, you can just pull it off and put the eliminator pulley in its place, unless you wish to fab your own. Therefore, no chip worries, it will do nothing.
You can just put a plug over the valves in the manifolds.
Old Feb 2, 2017 | 05:19 PM
mlm0's Avatar
mlm0
Did it to my 89, no problems, no codes
Old Feb 3, 2017 | 08:58 AM
eastbay77's Avatar
eastbay77
Does eliminating the air pump give a small increase in HP?
Old Feb 3, 2017 | 09:19 AM
ON 8TH's Avatar
ON 8TH
http://forum.grumpysperformance.com/...258&p=313#p313
did the ac compressor delete on my old 85 also.
im sure theres other info on this forum also.
Old Feb 3, 2017 | 11:02 AM
vader86's Avatar
vader86
Not really, the AIR pump pulley spins about as freely as the eliminator.
To air pump removal
