Firing problem
Old Feb 14, 2017 | 04:10 PM
antfarmer2's Avatar
antfarmer2
Originally Posted by Olschool
Just looked at them
Do the tests and spark as well and let us know.
Old Feb 14, 2017 | 04:12 PM
Olschool's Avatar
Olschool
I'm no mechanic so I kinda need some step by step I know use the test light in the fuse box but what u mean spark
Old Feb 14, 2017 | 05:33 PM
antfarmer2's Avatar
antfarmer2
Spark at the plugs where needed. And noid light and ohm the injectors. Youtube will show all.
Old Feb 14, 2017 | 05:36 PM
Olschool's Avatar
Olschool
Ok I don't have a noid light I'm going to have to find someone to work on it I guess
Old Feb 14, 2017 | 05:40 PM
s carter's Avatar
s carter
When you test the Inj. fuses the key needs to be in run position, also make sure of the ground on your Test light, finding a good ground can some times a bit of a challenge when testing.
Find an old spark plug that fits in the plug wire end and lean the Threaded end against the Block or Exhaust Crank car or start and look at the gap. If you see arching in the plug gap you have spark, Hopefully a strong one.
or you can Buy a off the shelf tester
http://www.autozone.com/test-scan-an...ster/10255_0_0
http://www.harborfreight.com/90-inli...ker-69023.html
Old Feb 14, 2017 | 05:46 PM
s carter's Avatar
s carter
Injector harness tester, I believe you can Borrow 1 in there Lend A Tool Program.
http://www.autozone.com/test-scan-an...set/948078_0_0
Old Feb 14, 2017 | 05:49 PM
antfarmer2's Avatar
antfarmer2
If your not willing to learn better just sell it because you will get drained by folks that will take advantage of you.
Just go to any part store and ask to borrow their noid light. They will just lend it to you if they know you or charge a deposit that you will get back if they don't.
Old Feb 14, 2017 | 06:10 PM
GUSTO14's Avatar
GUSTO14
Ok I don't have a noid light. I'm going to have to find someone to work on it I guess.
Olschool, where are you located? If you post some info in your profile, there may be a Forum member that lives nearby that can provide assistance. If not directly, surely someone can direct you to a reputable shop nearby that is reliable and comfortable working on the C4 Corvettes.
Good luck... GUSTO
Old Feb 14, 2017 | 06:12 PM
Olschool's Avatar
Olschool
In Salisbury nc
Old Feb 14, 2017 | 06:27 PM
GUSTO14's Avatar
GUSTO14
In Salisbury nc
That's pretty convenient, you need to send a PM to DUB (Forum Name)
https://www.corvetteforum.com/forums...47173-dub.html
DUB's in the Charlotte area and hangs out in the C1/C2 and C3 Forum mostly. He's a great resource and should be able to help. He runs a shop in the area and if he can't help, he will certainly steer you in the right direction.
Good luck... GUSTO
Old Feb 14, 2017 | 06:28 PM
Olschool's Avatar
Olschool
OK thanks
