Hi All, 1996 Collectors Edition LT4. Threw a MAF code. Need to clean the MAF sensor, however unable to figure out how to unclip the unit from the airflow intake hoses. Pic attached; clips on left and right side. Is there a special tool needed?
Any help is appreciated. Thanks
I took a small screwdriver and put it in the crimped section and turned it to open it up until it would come off the hook. When I put it back together, I used a needle nose pliers to squeeze the crimped section back together.
