shifter problem
Old Sep 25, 2002 | 09:14 PM
Iceman4021's Avatar
Iceman4021
Default shifter problem
is there any easy way of getting the pin out of the shifter ****.
Old Sep 25, 2002 | 10:10 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: shifter problem (Iceman4021)
If you mean on a six speed, yes.
I assume you have the shift pattern button out already.
Clamp a small pair of vice grips onto the wedge and tap in an upward direction with a hammer. Do not try to wiggle it out or pry it out, you will only end up with a black eye or a hole in your roof.
Old Sep 25, 2002 | 11:27 PM
Iceman4021's Avatar
Iceman4021
the black eye and busted lip sounds like what will happen with pat trying to turn a wrench
To shifter problem
