digital climate control panel
Old Mar 31, 2017 | 09:10 PM
Varoom - Vette's Avatar
Varoom - Vette
Default digital climate control panel
Another issue with this vette, temp. control panel won't adjust to the higher temp. (red button) works only to lower temp (green button). I've heard you can take them apart and clean the contacts, I've heard you can break off tabs and other nightmares about cleaning these contacts here on the forum.
Any tips on doing this without catastrophe?
Thanks............
Old Apr 1, 2017 | 08:35 AM
Drifter36's Avatar
Drifter36
Thanks............
There's a couple of very good videos on YouTube. Do a quick search. I did mine a few months ago. Used a soft pencil eraser to clean the contacts. Works perfectly now.
Old Apr 1, 2017 | 08:47 AM
Drifter36's Avatar
Drifter36
Thanks............
Here's a link to Ozz's video
Old Apr 1, 2017 | 08:55 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
I want that guys Tee- shirt
Old Apr 1, 2017 | 09:22 AM
TiIngot's Avatar
TiIngot
I did the fix years ago and wrote this post. If the link is still active print it and it will walk you through the steps.
http://forums.corvetteforum.com/show....php?t=1519199
Not that hard to do at all.
Old Apr 1, 2017 | 05:49 PM
Varoom - Vette
Thanks for the info. But my 87 is totally different removal and construction-wise. But I plan on using your plan on cleaning the contacts...thanks again!
Old Apr 1, 2017 | 05:55 PM
Varoom - Vette
Here's the link I found for the 1986 - 1988 vettes. Very good info.
https://www.corvetteforum.com/forums...post1568603057
Old Apr 2, 2017 | 08:21 AM
dizwiz24's Avatar
dizwiz24
Thanks............
i simply pushed the face of mine forward - it must have freshened up or broken free some corrosion on the contacts.
i had the same issue on my 93 and doing that fixed it
Old Apr 2, 2017 | 08:43 AM
Varoom - Vette
Wow...what a great tip. I just went out and tried that and it did make the higher temp. (red button) adjust to a higher setting. But, I had to keep pushing on it to get it to go higher at each degree, at least I know how to get it to adjust when in need for now. Looks as if it's definitely the contacts and I'll still need to disassemble and clean them...but for now this works! Thanks man!!
To digital climate control panel
