C4 Shock Replacement Recommendation
Old Mar 11, 2020 | 04:55 PM
  #41
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
are you z51? what is your intended driving style?
Old Mar 12, 2020 | 12:17 PM
  #42
MrBigDee's Avatar
MrBigDee
Yes, I think I have Z51.
Generally cruising but I do not want too soft, a track might be a right word. I have a stiffer VBP spring at the back and I lowered the car's rear slightly
Old Mar 12, 2020 | 03:06 PM
  #43
DGXR's Avatar
DGXR
I got the stock B8 Bilsteins for my base coupe, they are too soft for me. Wish I'd gone with the B6 which I believe is standard shock for the Z51 package.
Old Mar 12, 2020 | 03:24 PM
  #44
Krusty84's Avatar
Krusty84
I put the KYBs on my '84 two years ago. $100 total from Amazon then and... just checking now.... $102.96 total to the door with Prime if you ordered today.
Old Mar 13, 2020 | 04:42 PM
  #45
MrBigDee's Avatar
MrBigDee
So is B6 Bilsteins stiffer than B8?
Old Apr 25, 2020 | 01:52 PM
  #46
Colby Colter's Avatar
Colby Colter
Cruising
Default need help finding correct part
Hey everyone, need help with part number for my 1996 C4 corvette.
Ordered the Bilsteins off amazon and they dont fit. Car is jacked up right now and I discovered all 4 OEM shocks have a hydraulic line to a hydraulic reservoir. Anybody know where in the hell to find these parts? Im guessing it is part of the electronic suspension.
Dealership says they are discontinued. Oreilly and Advanced Auto only had the shocks without the hydraulic line. This is such a dumb problem to have.
Thanks.
Colby
Old Apr 25, 2020 | 02:33 PM
  #47
VikingTrad3r
Oil Producer
hydraulic lines from your shocks?
please look on your rpo sticker for fx3. thnx.
Old Apr 25, 2020 | 10:29 PM
  #48
Vetteguy42's Avatar
Vetteguy42
Just to add to this, rockauto has Bilstein’s on sale. I had a discount code (5%)that was able to apply, but with tax, and freight, total $358. Hope this helps some people
Old Apr 26, 2020 | 01:26 AM
  #49
Nomake Wan's Avatar
Nomake Wan
Thanks.
Colby
Correct; you have the horrible 1996-only "Selective Real-time Damping" system. A clip of this system can be found in the owner's manual here: https://www.youtube.com/watch?v=5-B1Pa33z90#t=20m52s
Parts for this system are no longer available new, and are prohibitively expensive NOS and almost certainly useless used. Your only option if you have this system, from what I've researched, is to disable the sensors via bypass plugs (search for "CORVETTE F45 SUSPENSION SIMULATOR KIT") and then install "normal" suspension, like the shocks that you already found.
Old Apr 26, 2020 | 01:51 AM
  #50
VikingTrad3r
Oil Producer
wow. i learned something! thnx. had no idea about f45
Old Apr 26, 2020 | 11:50 PM
  #51
Colby Colter
Cruising
Thanks Nomake Wan. That's exactly what I ended up doing Saturday, after I posted here. I left the lines in case I ever found the correct shocks, but plugged them and zip tied them out of the way. And went ahead and installed the Bilstein shocks that I had.
Car drives great.
Old Apr 26, 2020 | 11:52 PM
  #52
Colby Colter
Cruising
Yes, can you believe it?!
Old May 12, 2020 | 10:56 AM
  #53
JD620's Avatar
JD620
I believe that B6 Bilsteins are base (HD) and B8 are Z51 equivalents. I have base with new B6 and still a bit soft on rebound resulting in quite a bit of porpoising (front to back float) but likely more to do with soft base springs. Had Monroe that were decidedly not sporty - Go with Bilsteins or Konis (had on my Alfa GTV years ago).
Looking to know of anyone's experience with the newer Ridetech Streetgrip kit
Old May 12, 2020 | 11:13 AM
  #54
DGXR's Avatar
DGXR
^ I think you're right, I got the numbers turned around
Old Jul 22, 2020 | 08:29 AM
  #55
IowaClass65's Avatar
IowaClass65
Okay, Bilsteins it is. Will the B8 be too stiff for a 1992 Convert, NON Z51, weekend cruiser only. No track time. Thanks!
