Won't idle down
I have a 85 tune port with 27k for miles I have a intermittent problem the car won't idle down below 15-1600 when this happens and it's getting to happen more often the 4+3 overdrive kicks on and off on its own were should I start??
ECM requires closed loop to enable overdrive.
large vacuum leak, whether that is a defective stuck open IAC valve or a rotted hose for a faulty EGR diaphragm or a leaking brake booster check valve or a compromised intake manifold gasket.... create a condition where your O2 sensor sees a higher air to fuel ratio and causes injectors to dump more fuel in, which evens out the air to fuel ratio but causes the car to run poorly which kicks the car out of closed loop, which forces the disengagement of the overdrive unit
everything is so interconnected that as aklim says it is important to see which sensors are with you and operating specs and which ones are not.
you may in fact have more than one thing happening. You may have a massive vacuum leak, and you may have a sensor that is required to maintain close to the operation that is on the fritz. But this situation is definitely on the table where your huge vacuum leak could be the cause of everything.
personally, my advice is to go through the minimum Idle procedure right now, do a Google search for it, while you are waiting for your scanning system to be available to you. It is possible that someone messed with your throttlebody blades so bad using the screw that even at a zero IAC you are holding a very high rpm. If that's all it is, The minimum idol procedure will fix it. ak doesnt like to recommend that procedure because if the IAC valve is faulty it won't work. I agree with him. But this is something you could do and it takes about 5 minutes while you are waiting for the scanning system to arrive. The second thing you could do while you're waiting, is as the poster above said, look for vacuum leaks. Chances are, it's a vacuum leak. I get in there with a can of brake clean or WD-40 or something that is flammable and I spray until I hear an RPM increase.
again, sorry for the complex reply but hey these are complex machines!
Last edited by VikingTrad3r; Apr 23, 2017 at 01:05 PM. Reason: siri really bad on this one lol.
