fuel pressure.
Old Apr 30, 2017 | 07:45 PM
skidball's Avatar
skidball
Default fuel pressure.
Hello,
92 lt1. Finally checked fuel pressure. Turn key to run. Had 10 psi. Started car, went to 40 psi. Removed vacuum line at fpr, went to 48 psi. Replaced vacuum line and stayed a steady 40 , going to 43 psi when I rev the engine. Shut the car off, and drops 40 to 0 in less then a minute. No fuel at fpr, and maybe the car starts a bit slow the first time sitting for a couple of days ? Drives good, and idles good. Starts right up all the time. Could it be a bad check valve in fuel pump ? And what If I also had a bad fuel pump relay ?
Old May 1, 2017 | 11:38 PM
aklim's Avatar
aklim
Have you tried clamping off the feed line AFTER you get it to pressure and see if it drips back? Pulled the FPR hose to see if there is any gas?
Old May 2, 2017 | 08:32 PM
Kevova's Avatar
Kevova
Fuel pump check valve is most common cause. If FPR diaphragm is leaking; fuel would leak from hose when disconnected and engine is running. If you remove well at fuel tank filler it possible to block off fuel lines to isolate source of leak down.
Old May 2, 2017 | 09:49 PM
aklim's Avatar
aklim
Or the pulsator in the tank could be leaking
Old May 2, 2017 | 10:05 PM
skidball's Avatar
skidball
Hello,
I replaced pulsator with fuel line last year. No leaking fuel at fpr. I don't think the injectors are leaking as many times as I have looked for leaks or drips. I think it would be a massive fuel injector leak to lose so much pressure so fast ? I'm going with the crazy , crazy ideal that when I take the fuel cap off the fumes are overwhelming, like the gas is being poured in the tank ? thinking new fuel pump and sock in the near future ?
Old May 2, 2017 | 10:07 PM
aklim's Avatar
aklim
Originally Posted by skidball
Hello,
Buy is it rated for submersion? Not sure if the clamps could be loose? Have you tried crimping the line after getting it to pressure?
Old May 3, 2017 | 09:26 PM
skidball's Avatar
skidball
Hello,
I tried to clamp the lines, but no go. It runs and drives great. I am planning on changing the injectors anyway. Someday. Anything over and above that ? I don't mind changing a fuel pump or even a fpr if I need to.
Old May 3, 2017 | 10:22 PM
aklim's Avatar
aklim
What exactly did you do and where did you clamp the lines? How did it become a "no go"?
Anyday you do it, they aren't worth crap. "Runs great" means nothing when you don't have anything to compare it to. Injectors don't go bad suddenly on an "only" basis. They go bad gradually/
Without a proper test, you can change everything you want. You may even get lucky and fix any issues you have. I believe it is called the "shotgun approach" or the "Throw parts at it approach". Both get costly and frustrating but YMMV.
Old May 3, 2017 | 10:30 PM
A Peter C4's Avatar
A Peter C4
Maybe have a qualified tech. do a hands on diagnosis and find out exactly what is going on.
Old May 3, 2017 | 10:37 PM
aklim's Avatar
aklim
Depends. How lucky is he? The Shotgun Approach has been known to fix things if you are lucky and torpedo your wallet below the waterline if not. So, you got to ask yourself a question. "Do I feel lucky?". Well, do ya, punk?.
Old May 6, 2017 | 09:05 PM
skidball's Avatar
skidball
Yes I agree with the shotgun method. LOL. I'm getting there. Be patient .
To fuel pressure.
