New problem ?
Old May 3, 2017 | 09:33 PM
skidball's Avatar
skidball
Default New problem ?
Hello,
92 lt1. Was messing around under hood tonight. Nothing major. I noticed that when car was in park, automatic. three well spaced times I reved the engine to say 2500 rpms , and when it dropped down the 650 rpm. The dash and door lights blinked on and off ? What's going on ?
Old May 3, 2017 | 09:39 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
check your voltage regulator on your alternator
Old May 4, 2017 | 05:21 PM
pcolt94's Avatar
pcolt94
Originally Posted by skidball
Hello,
Was any door open at that time?
Were the door lights on or off before you reved the engine?
What position was the headlight switch?
I don't know enough to make a valid suggestion of a direction yet. But if you want a off the cuff guess at this time, check to door switches for proper adjustment. Is the idle speed motor working properly, 650 might be a bit low.
To New problem ?
