Plug wires...
Sep 27, 2002 | 08:26 PM
Plug wires...
Anyone have a preference on plug wires, i.e. what kind to use? I'm replacing mine, it's a 94 LT1 mostly converted to an LT4....30k miles...
Sep 27, 2002 | 08:36 PM
Re: Plug wires... (tomservo)
I dont have an LT1 but I have had good luck with Taylor and MSD 8.5s
[Modified by Rob90, 6:37 PM 9/27/2002]
Sep 27, 2002 | 08:41 PM
Re: Plug wires... (Rob90)
MSD superconductors, the 8.5mm, best wire going period. the taylor spiro pros aren't bad but they won't resist oil & under the hood junk nearly as well as the MSD. if a taylor gets oil on it they can & will leak spark. if the wires are touching where the oil soaks through you'll crossfire.
Sep 27, 2002 | 09:26 PM
MSD 8.5 Super Conductors!! :yesnod:
Sep 27, 2002 | 09:29 PM
MSD all the way, quite possibly the best plug wires available. The only drawback is that they do not fit the stock wire looms.
Sep 27, 2002 | 09:40 PM
Re: Plug wires... (Nathan Plemons)
MSD :yesnod: :yesnod: :yesnod:
Sep 28, 2002 | 12:05 AM
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I'm using the stock OEM red LT4 wires.
Sep 28, 2002 | 03:43 AM
Taylor Spiro Pro in Red :yesnod:
Sep 28, 2002 | 07:36 AM
Did you make your own wire looms, or are there ones you can buy?
Sep 28, 2002 | 07:37 AM
Re: Plug wires... (mackeyred96)
Hard to argue with a man with an 11sec car :)
Sep 28, 2002 | 08:55 AM
Buy some looms at Autozone.
Sep 28, 2002 | 12:09 PM
MSD's :yesnod:
Sep 28, 2002 | 01:04 PM
Maybe it would be a 10 second car with others. :jester
Sep 28, 2002 | 06:00 PM
Re: Plug wires... (95AquaC4)
It's what I am running...
Sep 29, 2002 | 12:09 PM
Re: Plug wires... (baddmann)
ACCEL 8.8's w/ "Made for You" wire looms that connect to the valve cover center bolts. Wires work great, but next time I'm going with something that I can tailor fit to the engine. Some of the wires I have are too damm long. Additionally, half of this set are 90 degree boots at the plugs, the other four have flexible connections. Seems like the #6 plug (the one behind the dip stick) is the only one that really needs the flex connector. My .02.
Bruce :chevy
Sep 29, 2002 | 08:39 PM
Re: Plug wires... (DDMMCPO)
MSD 8.5mm's here as well. :yesnod:
Sep 30, 2002 | 12:17 AM
Cruise-In IV Veteran
Cruise-In V Veteran
Re: Plug wires... (R94 LT 1)
taylor 409s :D
Sep 30, 2002 | 12:23 AM
Re: Plug wires... (CORKVETTE1)
I run the Taylor 10.4 mm 409's best wire period (IMO). They have a fitted set available, it fits perfectly, but of course because of the 10.4 mm wire size you must use their looms.
Thomas
