1989 Smog Pump Delete Question
Also, will removing all the smog parts throw any codes? From what limited info I found on here looks like no, the AIR is not tied to the computer. Thanks in advance.
I believe one should respect the environment but for my C4 that gets driven less than 4000 miles a year. I'm not going to do that much harm since I still run a cat. Look at all the people that want to change X-pipe's and remove the back cats that are not monitored.
now, this is just me, but if i'm looking at a car, and I see major component missing, like the smog pump, I'll walk away. gawd only know what other crazy stuff has been done.
Not selling my 35th. Beside I can't remove anything until 2023 by state law.
But I would if I could.
yeah, I can see where working an extra hour on your car would bum you out, and the extra 5 minutes to remove those two 10mm bolts - damn, that would cause just about anybody a nervous breakdown
- BTW, that smog equipment is also covered by federal law, not just state, and i'm thinking federal has no timeline -
I am looking forward to no state inspections. I can do what I want then. By that time I will be so old I doubt I will be driving my C4 more than 1000 miles/year. Save the wave.
NOW, IT'S NOT A RELIGION TO ME - I'M BY NO MEANS A TREE HUGGER, so let's get that straight, but there isn't a day goes by here where someone asks about ripping off the smog equipment. usual reasons - clean up the engine compartment - yeah, like they have some sort of show car, easier to work on the engine, right, just how much time overall do most folks spend under the hood working on their car? some of these folks are barely capable of changing their oil. how often are most people pulling plugs - once every couple years if that? and then there the performance and gas mileage gains. anyone that thinks they're going to see noticeable gains in anything is nuckin-futs. bottom line - most folks removing emissions equipment have no phucking clue what they're doing. just another bubba in there phucking up another corvette. now, it's your corvette and you can do pretty much anything you want, for me, i'm a little bit of a purest, and I see no reason to remove it. so, full circle and back to my original question, WHY?
