92 Cooling fan issue
Old May 10, 2017 | 03:01 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default 92 Cooling fan issue
From a cold start the fans come on and stay on. Coolant sensor?
Old May 10, 2017 | 03:11 PM
JimLentz's Avatar
JimLentz
Is the A/C on? What temperature does the digital readout show?
Old May 11, 2017 | 09:04 PM
pcolt94's Avatar
pcolt94
Both fans should not come on from a cold start with the AC off. If the AC was on only the driver's side fan should come on. The passenger side fan is programmed to come on at about 239*.
If both fans are coming on at start, it may be in limp home mode. I would check the codes as there are probably some on module 4. This may give you a direction of what to look at.
But before I'd tear into anything, I would clear the codes but rather than using the dash buttons, I would disconnect the battery so the ECM does a full reset.
Start and drive the car again and see what the fans do and re-check for codes. Post codes if you want direction from the Forum.
I'm going on the assumption the car has been running normal and the problem occurred. And not a situation where you just got the car and someone did a botch job on the wiring.
Old May 11, 2017 | 11:09 PM
sailor92a's Avatar
sailor92a
Cruising
Default fans on
my 90 had the same thing, code 15 replaced coolant sensor and works like a champ. no check engine light.
Old May 12, 2017 | 09:14 AM
87bob's Avatar
87bob
Great information!
Old May 12, 2017 | 06:43 PM
87bob's Avatar
87bob
Default Update
I haven't be able to work on it but today I had to move it. With the key in the on position no fans. At start up momentary no fans then both fans kick in.
To 92 Cooling fan issue
