Climate control lit up but no numbers or control.
There is 12 volts that comes out of the radio receiver box (CDM) that feeds the antenna relay and the Bose relay. The Bose relay then switches power to all the speaker boxes so the amplifers will work. Without that voltage (12 vdc) there will be no sound. So it seems to be a common problem for both no sound and antenna.
I can't tell you why the voltage from the radio box is not there. So you have to find out why. The pink wire on the Bose relay is the voltage feed from the radio box which turns everything on.
If when you shorted something out, don’t know if you damaged the radio box is the reason the voltage is not there. If that’s the case, the box would have to be sent out for repair.
