current flowing - getting electrocuted while standing on my dynomat -- concerns!!
The previous owner used some sort of foil based sound deadner. You can see pictures of it as it sits in this post here.
i had the battery connected to test the different switches and I was getting electrocuted while standing in the driver side wheel well on top of the dynomat stuff.
The antenna motor is whirring away. Its broken and it runs constantly (am replacing with an amplified hidden antenna).
So is what I am feeling the grounding to the frame of the car, and i get electricity coming throught the seat base bolts, into the foil, and into my barefeet?
The reason I am having concerns is that the aluminum rails on my driver side seat base were completely corroded and eaten away, in what could only be galvanic corrosion i would think. on all 4 holes, they were all enlarged to over the size of a quarter. could the electricity that i just picked up in my floor have been causing that aluminum to corrode around all 4 seat base mount studs???
to sum up:
standing in driver foot well, carpet uninstalled, on top of foil sound deadner, with antenna motor whirring away, and my feet were getting zapped.
thoughts guys? i did search it but the circumstance is a bit unusual and I did not get a single hit!
I am thinking that it had someting to do with the orange power seat hot lines that were sitting in the floor boards where I was standing.
Havn't tried to recreate it yet.
just for clarity, i wasnt being zap zap zapped. it was tingling like there was current through my feet.
like if yoh have ever been to the physiotherapist and they lut the tens machine on you and run some current through your body.
Kind of like when my son came out and admired my new electric fence, I had shoes on and he did not. I reached out and held onto the wire, I felt a mild tingle, my son put his hand on my shoulder and it nailed him really hard.
Follow the earlier advice about pulling fuses. Be methodical and take your time. You might want to put a voltmeter between the aluminum material and the ground of the car. if you can measure the voltage it would help solving the mystery.
Maybe the installer put it up so high under the dash that he is shorting something out. There are many sources to pick up the 12 volts up there in the dash.
I am a battery specialist and this is the first time I have heard anything like this.
I was in Abu Dhabi building a Photo-voltaic power system and one day I sat on a 12 volt starter battery (for the generator) and my whole body was dripping with sweat (124 deg F) and it lit my *** up, almost literally. It sure got my attention so it is possible to get shocked by 12 volts despite what people tell you.
Make sure that you don't have anything with 120 Vac hooked up to the car. You might also check the output terminal of the alternator. With the engine running check it for Volts dc and then check it again to be sure that your diode bridge isn't damaged by using a multimeter and test the alternator for AC voltage coming out of it. If there is AC coming out your alternator, it is bad.
i had the seat power wires laying in the floor pan with me but its not like the metal pins were touching the foil. they are in the plug casing.
im finishing up a few things to get the center consul frame installed and then ill do this test and try to recreate it.
i was barefoot standing on the foil but not wet.
Could be caused by corrosion at ground chassis points or possibly the antenna ground point is not at chassis potential even though it has power and runs.
Are the power seat terminal ends touching the dynamat?
