flicker dash lights and more . . .
thanks - yes definitely one thing at a time
ok - so I cleaned a few of the grounds and I thought I would check as I go - - I started it and all the lights are pulsing - under the hood, dash, door tail - it was like Christmas -the volts on the dash read all the way up to 15v - then I thought for the heck of it before I hoist the car up or tear into the dash - let me disconnect the alternator and start the car - the volts read 11.5, and not one light flickered or pulsed and they all had shown nice and bright
so this sounds like an alternator problem? yes?
Sean
Sean
I had ordered a powermaster 120 amp alternator for replacement and a rebuild kit just in case- also for the sake of wanting to know how and if I could ($13) there were a few issues with the power master -so they are sending a new one for exchange -
the long and the short - the lights do not flicker any longer - however, the volts now only read 11.4 - 11.7 and they have a red light next to them - I am presuming that's not a good red light?
the volts read steady between those numbers when driving - but I went from 14.3v before to 11.4 - ish should I be concerned? the battery is roughly 6 months old. I am going to put a charger on it to see what happens - but that seems like quite a change
any ideas or help would be greatly appreciated
Sean
Sean
Take a multimeter and measure the output of the alternator at the alternator itself...see if it's match what the dash shows. 11v is a bit too low and sounds like a bad alternator...this will cause issues when running a lot of power hungry devices like headlights as the alternator may not have enough power/amps to maintain a proper battery charge level.
sb66 (07-05-2017)
thanks, that is what I am afraid of as well - I do not want to end up stranded . -
to test, that is the red cable to ground(on the alt.) and compare to battery correct?
thanks
Sean
thanks
Sean
sb66 (07-06-2017)
one more stupid question about this - I was attempting to test resistance between positive battery lead and the connection on the back of the alternator - red wire - the ohms reading that I got was o.o and o.1 - to put the cherry on top of stupid - is that good or bad?
thanks
Sean
thanks
Sean
thanks
Sean
thanks
Sean
Switch up to Volts DC and check from that post to ground with the engine running.
sb66 (07-06-2017)
ok will do
thanks
thanks
I wanted to take a minute and say thanks to everyone for helping with this - you get to learn a lot about your car going through even the simple things and it's great having a group of people that are willing to help you out.
I checked everything re-checked, I finally decided to take the alternator off and retrace my steps. for some reason in the back of my mind I kept wondering if I got the brushes and springs to stay in place when I put it back together. I could not tell when I opened it up, but I put it all back together and tried again - 14.1 - 14.2 upon firing it up, everything running well and flickerless. I ma not sure what I missed the first time but I got it right the second. I still have the powermaster 120amp on the way - just in case, but it was nice to see it work and learn a few thing along the way
unfortunately, I noticed a lot of fluid/ wet goop on my power steering pump - that must be next - never-ending, but fun nonetheless!
thanks everyone
Sean
thanks everyone
Sean
thanks everyone
Sean
thanks everyone
Sean
