C4 1996 running hot
Old Jun 23, 2017 | 11:14 PM
Joan Giovanni's Avatar
Joan Giovanni
2nd Gear
Default C4 1996 running hot
Replaced thermostat, radiator sensor, and changed antifreeze and she runs too hot any suggestions for troubleshooting appreciated
Old Jun 24, 2017 | 12:26 AM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Do you already clean your radiator ?
A water hose is useful
Old Jun 24, 2017 | 12:48 AM
Eduardo L98 1991
https://www.corvetteforum.com/forums...peratures.html
Old Jun 24, 2017 | 07:48 AM
haxxx's Avatar
haxxx
I flushed my coolant early this year and found an issue that I was surprised didn't give me high temps.
First I took the black tank at the top and the clear tank from the bottom completely out of the car. The black tank had a lot of junk I flushed with a hose. I'd basically fill it, shake it and drain it. Probably like 20 times until orange sludge stopped coming out.
The clear tank has a thin line going to it. The part of the tank the line connected to and the line itself was completely clogged. It was basically a super fine sand like sludge. This crapped resisted 100 psi of compressed air for a bit until it finally blew out.
Old Jun 24, 2017 | 08:19 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
After you have done the flush and fill process, you will need to check your air flow. C4s are especially vulnerable to junk making its way in between the AC condenser and the radiator. This will REALLY cut down on your air flow and make your car run hot.
Here is what I found when I popped the shroud off my (new to me) 89 last weekend. I was doing some PM and found this:
Old Jun 25, 2017 | 10:25 AM
jimmers's Avatar
jimmers
Whats too hot? These cars run pretty hot as it is, so it's hard to say if something is wrong without letting us know what the temperature is.
Old Jun 25, 2017 | 10:33 AM
pcolt94's Avatar
pcolt94
And also after what period of time does it get "to hot" and want is the ambient air temperature when it happens.
Old Jun 25, 2017 | 10:44 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
His only other post is also asking this same question.
Need answers to some of the questions on this and the other thread before going any farther.
https://www.corvetteforum.com/forums...nning-hot.html
To C4 1996 running hot
