Oil Change Time
Old Jul 10, 2017 | 05:52 PM
  #61
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by JrRifleCoach
Did you just pitch a marketing piece as an "article"?
I think most of us know not to use OEM recommended oil for break in. I don't think the OP is breaking in a new aftermarket cam though.
Old Jul 10, 2017 | 06:35 PM
  #62
Joe C's Avatar
Joe C
FWIW when ZZP concentrations were reduced, many old flat tappet cam motors were grinding lobes.
PROVE IT! not some you-tube video, not some mag rag article, and not some hearsay. PROVE THIS GUY WRONG - http://www.nonlintec.com/sprite/oil_myths.pdf
BTW, quantify "many."
if any of what you're saying was true, I would think the car manufacturers would have been pumping technical service bulletins out the yin-yang. not one manufacture has addressed anything on additional zinc requirements for their engines.
all we're sayings is you just need to follow the manufacturers recommendations on weight or viscosity, and change at the recommended intervals and you're good to go. the oil companies formulate, and API spec the oil (currently SN, which is backward compatible), to meet current engine requirements.
PROVE ME WRONG!!!
Old Jul 10, 2017 | 07:26 PM
  #63
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
B/c in the other thread that I linked, someone said,
recent camshaft failures is unprecedented.
I believe the word "epidemic" was used as well.
That is not specific either...but Come on. Those words imply a much larger problem than there is; there is no epidemic, there is no "unprecedented" failures. Although not as severe, I wonder what you mean by "many" too. B/c in all my personal...and all my fleet experience, I've seen zero "old flat tappet cam motors were grinding lobes". It isn't happening. Oil today is way better than good enough.
Old Jul 10, 2017 | 08:17 PM
  #64
confab's Avatar
confab
Originally Posted by confab
If true.. Apparently GM now officially recognizes instances (competition driving) where 5W30 isn't adequate?
Why Mobil1 15-50?
There's two instances now, both dealing with performance appications specifically, and they call for a particular brand, and grade, of motor oil?
What, it's like magic? Blessed by a Voodoo Oil Priest or something?
Old Jul 10, 2017 | 08:21 PM
  #65
confab's Avatar
confab
Why Mobil1 15-50?
If 5W30 isn't adequate in these circumstances.. Why not 10W40? Or 20W50?
Or some other brand?
Old Jul 10, 2017 | 08:57 PM
  #66
Cjunkie's Avatar
Cjunkie
Okay.. I admit to becoming a little fascinated with the Callaway Corvette's oil recommendation.
I was searching on it and a guy at another forum says this IS IN the 2016 corvette owners manual.
Thank you confab
Old Jul 10, 2017 | 09:02 PM
  #67
Cjunkie's Avatar
Cjunkie
Originally Posted by Tom400CFI
I knew someone who had that "brilliant" idea. They knew it would work way better than GM's recommendation and provide better wear protection. One cold winter day, he fired up his Silverado after work, went back in to let it warm up. Came out 10 min later and it wasn't running -engine was seized. Oil was so thick it broke the oil pump drive shaft. Good idea...huh. Meanwhile, MY Silverado (same truck) cruises right on by 300k towing boats through the rockies, cold winters, hot SLC summers all on M1 5w-30. And it still performs like new (engine wise, at least!). How can that be???
There are other reasons why diesel oil isn't the OEM's recommended fill. You can do it...but I certainly wouldn't be going around make that "recommendation" to people, that's for sure.
Who runs 15w40 in the winter unless its a diesel? Spring, summer, and fall sure. Come Thanksgiving or Dec.1 you drain it.
Old Jul 10, 2017 | 09:19 PM
  #68
confab's Avatar
confab
Originally Posted by Cjunkie
Thank you confab
Np. This subject really interests me.
And ALL I find when reading about it is conflicting data?
I just want to know the truth.. FTW?!>!@>!>
Old Jul 10, 2017 | 09:22 PM
  #69
confab's Avatar
confab
Hemmings has an article that says the exact opposite of what I read here?
I read one study, it says this.. Another says that?
I dunno? Why is there such confusion on this subject? I don't get it?
Old Jul 10, 2017 | 09:30 PM
  #70
confab's Avatar
confab
HERE!! Hemmings says everyone is FOS.
https://www.hemmings.com/blog/2012/1...comments-block
But the next study says THEY'RE FOS!
And, it just leaves me confused?
Old Jul 10, 2017 | 10:07 PM
  #71
Joe C's Avatar
Joe C
well, I guess we could go on here forever, so my bottom line - i'm just going to keep doing what I've been doing with my 85 since the mid 90's. pretty much follow the owners manual for oil and change intervals. nothing fancy, no additives, everything pretty much by the book. the only thing lately I've been done different was switching to M1 high mileage synthetic (10W30). i'm driving about 5K per year with this car. at that rate, it's going to take another 20 years to hit the 250K mark. hopefully both me and the 85 will make it. so, i'm pretty much done here. folks can do what they want - honestly, I could care less - &
Old Jul 10, 2017 | 10:28 PM
  #72
81c3's Avatar
81c3
Guys, debate is healthy... no need to get frustrated... People really don't know certain things and are interested in real information. Stop arguing... ask and get answers... comment when you have a good piece of experience or information. Telling one person they're an idiot because you don't agree with them, makes you the idiot!!!
Some of us are older with more knowledge to share with the younger guys... that's Awesome!! Think of how many people just lurk here and may need a real answer for their own use.
So.... that brings me to another question I thought of....
Is today's conventional oil formulated with the same levels of ZDDP as when it was prescribed for the vehicle when it was made?
Old Jul 10, 2017 | 11:37 PM
  #73
JETS C3-C4's Avatar
JETS C3-C4
And another perspective:
http://www.enginebuildermag.com/2012...-what-why-how/
Old Jul 10, 2017 | 11:52 PM
  #74
Cjunkie's Avatar
Cjunkie
nope
Old Jul 11, 2017 | 12:08 AM
  #75
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Someone who thinks that they're a "Master Lube Brewer".
Which based on this thread, could be ~50% of the people. Everyone has some "brilliant" idea...this guy's idea was diesel oil. You've got your own version....and I have mine; use the OEM recommended oil, change it when due and enjoy engine life so long that the car falls apart around the engine.
Old Jul 11, 2017 | 12:11 AM
  #76
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I hear you. You could go mad trying to find...the "HOLY GRAIL OF LUBE POTIONS!" And still...you wouldn't get any clarity. So KISS, knowing that all brand name oils are way better than good enough, use the one that you fancy and do...this:
Old Jul 11, 2017 | 12:47 AM
  #77
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
PROVE ME WRONG!!!
Thats the beauty of this type of debate.
Nether side wins. Or loses.
Prove me wrong. You can't.
I can dig up plenty of info to support zinc and flat tappet cams.
And you can find plenty to deny it.
To Oil Change Time
Old Jul 11, 2017 | 01:20 AM
  #78
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^That is right. The search for "truth" and the debate of the theoretical could go on for eternity...and never be solved (that way). So we step back from that realm and then we look at real life results. What do we find? We find that in reality, the vast majority of engines that are running on "today's oil" are not just surviving, but thriving for 100's of 1000's of miles. To the point where the car is falling apart around the engine. And what conclusion can we draw from that?
Today's oils are the best we've ever had and way, WAY...better than good enough.
Old Jul 11, 2017 | 07:14 AM
  #79
confab's Avatar
confab
*screams*
*opens the cabin door and jumps out*
I've been using Mobil1 high mileage. It seems fine? It's a brand I recognize. It is affordable. It has high levels of these additives, but not so high they reach into the area where some folks claim they are dangerous.
I'm just going to keep using that till I learn otherwise.. Or see empirical evidence to the contrary.
Old Jul 11, 2017 | 07:22 AM
  #80
Joe C's Avatar
Joe C
- another spin master. way to put a spin on the topic at hand, in this case my previous post. you failed to add anything positive here. you stated -
I asked you to clarify that and define "many, and all you do is spin it back to me without an answer." I ask you to prove Bob Orlee's (from GM's Powertrain Fuels and Lubricants Group), prove his paper wrong. you failed to do that, but again, you spin it back to me. I make a statement that all that's needed is to follow the manufacturer's guidelines on oil and change intervals, and state "prove me wrong," which by the way you would have to prove GM wrong, and what do you do, spin it back to me. the thing is, I NEVER said you were wrong, but "somehow" you want me to prove you're wrong - . again, nice spin. you state you can provide plenty of info to support zinc and flat tappet cams, but fail to provide that info, and then again, spin it back to me to prove the opposite. again, you've failed to provide anything positive here, so in a way, you're right, nobody wins. have a good one...
