94 corvette
Jul 21, 2017 | 08:28 PM
94 corvette
how to hotwire my ac compressor to turn on so I can charge my ac system low pressure just changed compressor
Jul 21, 2017 | 08:37 PM
You might want to have this moved to C4 tech....
Jul 22, 2017 | 12:21 AM
Quote:
Originally Posted by
frodo84
Jul 22, 2017 | 01:05 AM
i don't see why you need to do that. just start filling it up then turn the ac on
Jul 22, 2017 | 11:30 PM
Jul 23, 2017 | 08:07 AM
You can try jumping the low pressure switch to get it to cycle.
Gary
Jul 23, 2017 | 10:46 AM
yd328
Gary
Big Darrell
Do you have a vacuum pump to evacuate the system?
Need to do this before you charge.
Jul 23, 2017 | 12:52 PM
HPS MASTER TECH
I generally agree with this and would if it is a C60 (manual system).
But the FSM (at least my 92) states:
"The C68 system may disengage the the compressor and set a 09 code (low Freon) fault code during the recharging procedure if the low pressure cycling switch is not bypassed."
