trouble codes
Old Oct 3, 2002 | 11:34 AM
atotalnincompoop's Avatar
atotalnincompoop
Default trouble codes
last night i tried to access the trouble codes under the dash on my "85, when i connected the 2 terminals no codes were flashed, not even the first one that always is displayed first to show that the system is working, the only thing that happened on one of my attempts was that the electric fan started up. anyone have any idea :cheers:
Old Oct 3, 2002 | 03:15 PM
Blue88's Avatar
Blue88
Default Re: trouble codes (atotalnincompoop)
If you jumpered A and B and turned the ignition to the ON position then the fan should have come on and the service engine light would start blinking. Maybe the Service Engine bulb is burned out?
Old Oct 3, 2002 | 04:27 PM
atotalnincompoop
Default Re: trouble codes (Blue88)
the service engine light is always on, it is on when i try to access the trouble codes, it just won't flash. The fan only came on one time and hasn't come on again when accessing the codes :confused:
Old Oct 3, 2002 | 05:22 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Does the SES light go off after you start the engine?
If so, sounds like you may have a bad connection at the A or B pins of the ALDL.
Old Oct 3, 2002 | 09:33 PM
atotalnincompoop
Default Re: trouble codes (65Z01)
the service engine light is on always, however it will not flash any codes, the pins in the terminal block apear fine :confused:
To trouble codes
