85 transmission problem
Old Aug 2, 2017 | 05:54 PM
Rocky Brian Lamb's Avatar
Rocky Brian Lamb
Cruising
Default 85 transmission problem
Does anyone know why my transmission jumps in overdive fast. It will go in at low speed. Thanks a bunch
Old Aug 2, 2017 | 06:03 PM
c4cruiser's Avatar
c4cruiser
Automatic or manual? And at what speed and RPM?
Old Aug 2, 2017 | 06:29 PM
Rocky Brian Lamb
Cruising
Automatic. 35-40
Old Aug 2, 2017 | 06:39 PM
confab's Avatar
confab
TV cable adjusted properly?
Old Aug 2, 2017 | 06:46 PM
Rocky Brian Lamb
Cruising
Yes
Old Aug 2, 2017 | 07:30 PM
confab's Avatar
confab
You sure you are feeling 4th and not lockup? Mine will lock in third.
Old Aug 2, 2017 | 08:08 PM
Silver85's Avatar
Silver85
Early 85 ECM was programmed to lock up at anything over 15mph. It was miserable. I got mine flashed and changed to 40 plus and it made a huge difference. Pull the EPROM and see what program you have. The .bin file can be found online.
Old Aug 2, 2017 | 08:41 PM
Rocky Brian Lamb
Cruising
It is like if driving a manual 2nd to 4th. It if you driving normal. If you go kinda fast when pulling out it don't do. I have just shifting in o.d. when I get up to speed.
Old Aug 2, 2017 | 10:10 PM
xrav22's Avatar
xrav22
Mine will lock at 42 in 2,3,OD, or if you floor it at any speed. My take on it is the TPI sensor locks the transmission on its own past 1/2 throttle. That is what I read somewhere.
Old Aug 3, 2017 | 02:56 AM
Cliff Harris's Avatar
Cliff Harris
These are the conditions for torque converter lockup on my car:
Vehicle speed > 40 MPH (it actually locks at 42 MPH on the speedometer)
Coolant temperature > 122°F
It will lock the TCC in any gear. I tested it for 1, 2 and 3.
Old Aug 6, 2017 | 06:50 AM
gerardvg's Avatar
gerardvg
The early ecm had this issue there was a recall to change this after a lot of complaints, you can replace the eprom with a performance one that has the lock up at higher RPM.
See below and read the changes, is probably the easiest option.
http://www.parts123.com/corvettecent...050f&ukey=6056
http://www.parts123.com/corvettecent...050f&ukey=6053
To 85 transmission problem
