1985 C4 rotors
Old Aug 2, 2017 | 10:03 PM
EWheater's Avatar
EWheater
3rd Gear
Default 1985 C4 rotors
I have a 1985 c4 with what look like 1993 sawblade wheels. The brake calipers appear to be stock, but the rotors bolt to the hub and the wheel lugs thread into the rotor. Is this needed for the different wheel offset? Does anyone know who makes rotors like this?
Thanks,
Eric
Old Aug 3, 2017 | 02:14 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Eric, your 1985 came with 16" wheels and those saw blades are 17". If you check with Mid-America Motorworks you may find the wheel adapters you need
Old Aug 3, 2017 | 02:49 PM
Benny42's Avatar
Benny42
From your description, it sounds like you have adapters on now to make the sawblabes fit right. Unbolt the rotor and see if that's how it works.
Old Aug 3, 2017 | 04:49 PM
c4cruiser's Avatar
c4cruiser
The stock C4 brake rotors simply slide over the wheel studs that are pressed into the hub. They are not bolted on separately. The wheels then slip onto the studs and the lug nuts attach the wheels to the studs. Lug nuts do not touch the stock rotors.
From your description, are you talking about wheel adapters for the later wheels? Even if you have adapters for the later wheels, the adapters would bolt on just like a wheel and the wheels would then be bolted on using lug nuts.
Any chance you can take a pic of your setup and post here??
Old Aug 3, 2017 | 08:52 PM
EWheater's Avatar
EWheater
3rd Gear
I'll have the car on the lift this weekend and take some pictures.
Old Aug 5, 2017 | 10:32 PM
EWheater's Avatar
EWheater
3rd Gear
I put the car on the lift and took the assembly apart. I thought the adapters were part of the rotor, but they are separate. I should be able to use standard rotors, I just need some of the nuts to hold the adapters on. I'm missing one on each wheel. Thanks for your response!
Old Aug 6, 2017 | 06:34 AM
gerardvg's Avatar
gerardvg
Hi
Looks like the adapters have studs missing, the adapters bolt onto your car with five nuts. You should have five studs on the adapters, looks like you will have to buy a new set of adapters.
Old Aug 6, 2017 | 07:51 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by gerardvg
Hi
OP shouldn't need to buy new adapters but only have maybe "ALL" studs replaced with appropriate quality product. Often the case with inexpensive adapters is the fact that the "spline spins" in the adapter. There's ways to secure the studs in the adapters if "spinning splines" are a problem.
OP certainly has a problem with the adapter he chose to snapshot. 2 new studs for sure and maybe just securing the 3 that are present. Seize the opportunity to do all four adapters at the same time. It's difficult to pass judgement from the snapshots but it appears that there's maybe a poor mix of nuts that hold the adapter to the hub on the car. I think best to check all of the suds in the factory hubs as well as all adapter and wheel hardware.
To 1985 C4 rotors
