1987 valve stem seals replacement
Old Sep 19, 2017 | 11:16 AM
baron5's Avatar
baron5
7th Gear
Default 1987 valve stem seals replacement
1987 corvette convertible with aluminum heads. I am replacing valve stem seals. My question- On the exhaust side My kit comes with 8 O rings and 8 white umbrella type seals. When I took the valve covers off and removed the springs the exhaust side only has o rings. Am I just using the O rings and discarding the other seals? They are not on my valves now.
Old Sep 19, 2017 | 02:48 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Duplicate post.
