Fuel Pump Relay Wiring
the original owner of my car, for whatever reason, messed with the wiring to the FP relay and I’m curious to know if anyone has a link or a picture from the repair manual as to which color wires go to their corresponding pins on the connector.
I would really appreciate any input I can get, hopefully someone sees this fast haha.
I'd suggest you actually get a correct year FSM (Factory Service Manual) so that you have first hand information at your finger tips. Did you ask the PO if there was a reason for his changes? Might have been a "real reason" the change was made.
You're sure it's the FP relay?
I bought the car (84 crossfire) as a project and one of the things I discovered is the relay was wired backwards, there for shorting itself out and frying a hole in the sides of it. Whoever was the one trying to restore it did not know how to do electrical repairs and I’ve been finding nightmares all over. As in, splice connectors. *shivers*
Long story short, I fixed that problem. Now onto getting a new relay and hunting other problem...
Thanks!
