Multipul misfire detected code
Old Oct 3, 2017 | 09:35 AM
MikieG1971's Avatar
MikieG1971
Default Multipul misfire detected code
I got that code a month ago then the ignition went dead. Turned out to be ICM. Car runs fine. Then light came on again. Car still runs fine. Same code though.
What are your thoughts?
Old Oct 3, 2017 | 10:16 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
A bit more information needed My over the internet mind reading not working to well today I guess I should have stayed at Holiday Inn last nite.
OK looked at your profile still no help, Sorry not going to view all your posts to find out. But they built C4s for 12 years so it has to be OBD. I would have to guess something is wrong or it would not set a code.
Old Oct 5, 2017 | 03:47 PM
MikieG1971's Avatar
MikieG1971
Its a 96 LT1. Last time the light came on it was same code. Then car was dead. Replaced the ICM.
Old Oct 9, 2017 | 08:59 AM
Kevova's Avatar
Kevova
P0300 if you have access to a oscilloscope it might show misfire. Check condition of ignition wires and plugs. It could be opti distributor cap and rotor. Vacuum leak is possible but it would be small since no lean codes.
Old Oct 9, 2017 | 09:03 AM
MikieG1971's Avatar
MikieG1971
I am sure at 68k these plugs and wires are originol. Also, there is quite a bit of cracked vacuum lines on the drivers side of the motor.
The line to the cruise control is litterally open.​​​​​​
Old Oct 9, 2017 | 09:36 AM
Whaleman's Avatar
Whaleman
I am not sure but I bet the pros on this site will say to fix the vacuum leaks first. Dan
Old Oct 9, 2017 | 10:01 AM
MikieG1971's Avatar
MikieG1971
Im not a vacuum guy. Does anyone have a source for a vacuum hose kit for a 96 LT1?
Also, if anyone has any experience with this project, about how much $$ in labor should it cost?
I am doubting there are any YouTube vids on it.
Old Oct 9, 2017 | 12:32 PM
jetskibruce's Avatar
jetskibruce
Vacuum lines should be fairly easy to follow, but checking the service manual for routing is recommended. Take a piece into the parts store and get a length to replace it end to end. There will be different sizes and perhaps some plastic tubing. Be careful poking around it is easy to break old plastic hose barbs and make things worse. A decent shop should be able to help, find one that knows older chevys
To Multipul misfire detected code
