Camshaft Research and Question
1st tops at 40
2nd 67ish
3rd at 94
And it takes about 13 seconds to be going that fast. Stock third gen or 84 vette. Limiting yourself to those rpms isn't saving you much.
Well, this I did not know! You got me with this one. However, the lower torque number may be remedied with a B-body camshaft paired with the TPI intake on my motor, and with the compression increased to 12. Also I found these comments on the subject and I can't help but lean towards the TPI intake.
Best thing you could do to improve that low end and midrange feeling is to add 4.10 gears if its a manual, or 3.54(or 3.73) in an automatic with a higher stall TC. Then it will feel more like an L98 off the line because you're getting into that power band more quickly.
So then my focus would be on a midrange & up cam, more like the LE Custom or LT4 Hotcam. Have the heads redone and install either of those, and I think you'll be happy, AFTER you do the gears.
Do you think the factory would have put the stock rev limiter at 5700 RPM if then engine could not safely be run there?
Is your car stock or have a stock tune?
You cannot run 12 to one compression with a short duration cam, the cylinder pressure will get too high and cause detonation. That is why people raise the compression when they add larger cams, the increased static compression ratio makes up for the lower low rpm cylinder pressure. That is why I stated in my previous post to pick a cam with more lift, same overall duration but greater .050 duration to allow more air to enter the engine for more power and more low end power. You need to understand what each component on an engine does before you can decide how to modify it for more power/torque and power band. How does each item complement the other? I understand your goals of low end power but do not understand your lower then factory designed RPM limit because that goes against your other goal of faster 0 to 50 MPH times.
YOU foul up the forum. If you knew what was good for you, you'd listen to the experts...not argue with them.
Here, this is the last help I'm offering your
:ing waste of forum space... What's your custom intake & a cam swap going to cost you? It's going to cost you at LEAST $2k.
How about a solution for all of your criterial for 1/2 that? Spend a couple hundred for a stroker crank for your rebuild...there is your "low RPM TOWAK MONSTAH...then buy this(or some facsimile thereof) for winter....
30 mpg SHITBOX
First, the very graph that bjankuski posted for you, very clearly shows that the LT1 actually makes more low end TQ. I bet that if you clench real hard, you can recall a similar but different graph that I posted (threads ago) that showed the exact same thing. The TPI doesn't make more low RPM tq; it make it's tq in the mid range; ~3200 RPM. That's not "low end" on a 5000 RPM limited motor.
The quote you're citing? The L98 is NOT "quicker off the line". You've been told this too, many times. Both cars 60' about the same; ~2.0x seconds and the LTq car is quicker in 0-60 tests...so how is a TPI car "quicker off the line"? It's not. So how is it going to give you that "real muscle car feel" that you wet-dream about?
Best of luck with your overpriced, underperforming build plan. Last edited by Tom400CFI; Jan 1, 2018 at 11:46 PM.
I would submit it's just as much your continued "engagement" that perpetuates the thread(s), frustration, and feelings of regret. I've been through those stages -- when addressing the points early on. To a certain extent, I may understand the guy more than himself or others. But, he is like my last girlfriend and the president. He's too egotistical, stubborn, and short-sided to UNDERSTAND other points of view. In both their cases, I finally accepted they won't change because they are INCAPABLE. Same with this guy. That's why I gave up....even though there's more to say.
In some ways, the responders including you/I are being as much/more abusive than him. Again, he is incapable of understanding what mistakes, statements and aspects of his approach CAUSE that reaction. Just as my ex-girlfriend and our dunce president, the light is on -- but no one is really home.
Is that enough to be banned? I'll be surprised if it happens. Just like I'll be surprised if impeachment ever happens. Stupid talk, poor understanding...and even dumb links/pictures (tweets...LOL) isn't the smoking gun needed to pull the plug. Sometimes, the ONLY course of action is to avert your eyes and just look away.
I suggest everyone tries it.
Last edited by GREGGPENN; Jan 2, 2018 at 02:15 AM. Reason: Added the last sentence
The scale is so entirely skewed, that it makes the difference(s) LOOK much worse than they are. Stretch the graph sideways 2-3 times before you get a better comparison to a modern, more representative dyno graph.
But more important than his intentions are the effects on the usefulness of this forum. Thread-shitting like this ruins the search functions for those who actually want useful information. Basically, someone has to sift through so much garbage in any results of a search that the forum becomes useless. I'm used to another forum where stuff like this is never allowed, for that very reason. You also aren't allowed to start multiple threads about the same topic for that same reason, but that's something Penix has done here also. So it's really for the good of the forum that he should be banned, and this abortion of a thread should be locked.
You are 100% right about not engaging him, though.
And this. The unwitting, coming here looking for GOOD information, may stumble upon this guys threads and become severely misled with horse manure.
I'm going to have to disagree with that. Both the horizontal and vertical scales on this graph start at 0 and go beyond the top data, and they are perfectly linear. And both axes' scales are similar in size: i.e., the graph is almost square, so neither rpm nor torque/power are emphasized unduly. And of course both engine's data are plotted on the same scales. So it's the opposite of skewed. You can certainly stretch it out horizontally if you want to make it look similar to another graph, but that isn't going to change what it shows.
It doesn't really skew the comparison, except that it makes the differences in torque look smaller than the differences in power. But it's a goofy and inaccurate graph in the sense that you pointed out.
