Thoughts??
Old Nov 21, 2017 | 12:58 PM
ZEROVETTE7's Avatar
ZEROVETTE7
Default Thoughts??
I hope the link works:
After driving it and warming smoke stars coming from dipstick tube when idle as you can see in the video.
Running smooth, temp normal just had it serviced with mobile1 oil, new filter..,.
the ride is a 91, L98, A4 with 68k on the clock.
Thought??
Old Nov 21, 2017 | 01:05 PM
Whaleman's Avatar
Whaleman
put in a new PCV valve. Dan
Old Nov 21, 2017 | 01:35 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Whaleman is correct. You PCV valve is defective and not allowing internal gases to escape "normally" so it backs up and comes out your dip stick.
Old Nov 29, 2017 | 03:44 AM
ZEROVETTE7's Avatar
ZEROVETTE7
Checked the PCV valve and it’s connections all seems ok and working properly..!!
Old Nov 29, 2017 | 03:46 AM
ZEROVETTE7's Avatar
ZEROVETTE7
I’ve noticed also some oil on the tube neck .. could be spitting from the dipstick tube.
To Thoughts??
