Torque Converter
Old Nov 21, 2017 | 02:03 PM
Turbo Bob's Avatar
Turbo Bob
Corvette Challenge Champ-01
Dragster Challenge Champ-06
Default Torque Converter
1995 Corvette Coupe. 46k Miles. Mods: Open Air lid with K&N filter. 1.6 Roller Rockers, 160 stat, Tune, Dana 44 with 3:54 gears, QA1 single adjustable shocks front and rear. Best ET 13.20 @105 on a M/T 275-40-17 drag radial. Best sixty foot 1.88. Looking to do an aftermarket torque converter over the winter. I know once torque converter is installed I will need the OBD1 Stall Wall issue addressed in the Tune.
Any and all thoughts and opinions are welcome. Thanks.
Old Nov 21, 2017 | 03:30 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I've been running a Yank SS 3200 TC for the past 70,000 miles on my 95 although I don't track my car at all.
If you don't mind.... what is the Stall Wall Issue that you mention above?
Old Nov 21, 2017 | 03:52 PM
Turbo Bob's Avatar
Turbo Bob
Mr P,
OBD1 stall wall issue occurs when using a higher stall converter. It usually happens when doing a burn out prior to drag racing the car at the track. The VSS signal to the PCM is lost which then puts the vehicle in limp mode which will start the vehicle in second or third gear prior to staging the car. It can be remedied by using an OBD1 friendly tuning software Tunercat and remedied by having the PCM not read the VSS signal.
Old Nov 21, 2017 | 03:58 PM
vette196's Avatar
vette196
That what I'm going to put in my car (or the Vigilante), I've been told not to waste money on others that are cheaper. How do you like the 3200 stall in your car?
Old Nov 21, 2017 | 04:05 PM
Mr. Peabody
Thank you Bob
vette196: I have been very happy with mine. It has made my 3.07 A4 a blast to drive............ but my non highway gas mileage has gone down as the fun has gone up
Old Nov 21, 2017 | 04:11 PM
vette196's Avatar
vette196
Thank you Bob
I thought they are lighter and more efficient....it must be the extra lead in your foot
I am upgrading to a 3.07 (from 2.59) and its an A4
My winter (and hopefully not Spring) project is LE2 ported & polished heads and intake, cam, 1.6RR, 30lbs inj.,LT headers and a tune.
What engine mods do you have?
Old Nov 21, 2017 | 04:43 PM
aklim's Avatar
aklim
How old is the trans? I wouldn't put a good TC into an old used trans. I'd rebuild the whole thing or forget it till it breaks.
Old Nov 21, 2017 | 04:46 PM
Turbo Bob's Avatar
Turbo Bob
Trans is original. Well maintained with 46k miles.
Old Nov 21, 2017 | 04:50 PM
aklim's Avatar
aklim
I wouldn't if it were my money. That old a trans and if it breaks, it craps all into the TC so if it happens in 2 years of purchase of a Precision Industries one, you can have a free "restall" where they cut it apart and clean it and weld it back.
I have broken 700R4s that are stock way under 100K so..... Depends on whether you will push it once you get some mods or not. If you honestly think you won't, think again.
Old Nov 21, 2017 | 04:55 PM
Turbo Bob's Avatar
Turbo Bob
May have do a rebuild on the trans while it out. Or find another trans and rebuild that one.
Old Nov 21, 2017 | 05:15 PM
aklim's Avatar
aklim
C4s have a shorter output shaft and different tail housing
Old Nov 21, 2017 | 05:18 PM
Turbo Bob's Avatar
Turbo Bob
Yes I know. Thanks.
Old Nov 21, 2017 | 08:00 PM
Cjunkie's Avatar
Cjunkie
Go with a Circle D and stay away from the other junk.
Get you 60’s in the 1.6x range and then you will have a 12 sec car.
What does your 98 run?
Old Nov 21, 2017 | 09:50 PM
Turbo Bob's Avatar
Turbo Bob
My 98 runs 11.70’s but broke a ring on number 7 this past season. Now has a crate LS3 376/525 from Jegs.
Old Nov 22, 2017 | 10:21 AM
Cjunkie's Avatar
Cjunkie
Have you run the LS3 yet? What trans will you be running with the LS3?
Old Nov 22, 2017 | 10:38 AM
383vett's Avatar
383vett
I've been running a Precision Industries Vigilante for years. Full throttle track lockups with zero problems.
Old Nov 22, 2017 | 11:25 AM
vette196's Avatar
vette196
Why is a Yank or Vigilante junk?
To Torque Converter
Old Nov 22, 2017 | 11:56 AM
aklim's Avatar
aklim
Haven't heard about too many bad things about any of the 3. Using PI because both builders use it not that I think it is any better than Yank or Circle D.
Old Nov 22, 2017 | 03:47 PM
Turbo Bob's Avatar
Turbo Bob
Haven’t run the ‘98 with the LS3. The trans is a built 4L60E by RpM Transmissions in Indiana. I’m also running a Precision Industries Vigilante 3600 Stall Converter with a built RPM rear with 3:73 gears.
Old Nov 22, 2017 | 07:02 PM
Cjunkie's Avatar
Cjunkie
That’s so old 90s stuff.
What does every quick Ford,GM, or Mopar run today...........Circle D.
Its like headers what do they all run.........ARH
Just sayin.
