hot wired fuel pump????
When I was replacing the stereo CDM on my 90 I must have shorted something and caused the ECM fuse to blow. The car would turn over, had spark but would not fire. It would start on starter fluid for a few seconds. The fuel pump would not run.
I then applied 12 volts directly to the fuel pump which caused the fuel pump to run and I had normal fuel pressure but it still wouldn't start. I then checked to see if the fuel injectors were getting power by using a noid light. The noid lights would not light up so I realized it must be the ECM.
I posted for help here and Cliff Harris suggested I check the ECM fuse. Yup, it was the fuse....
i'm getting a little confused on what exactly what the OP's done, but I would run a continuity check from the fuel pump fuse - the "120" circuit side, to the FP harness connector. to me, that would indicate if the power side of the wiring is good. the only other thing would be the actual "chassis" ground for the FP (circuit ground "150" in the circuit schematic). if both of those checks are good, the problem has to be upstream of the FP fuse to either side of connector C237 (circuit 458 side of the fuse). one simple test would be continuity check from pin A of the relay harness to the "458" side of the FP fuse. we are only dealing with power and ground here - it can't be that difficult to get the pump to turn on. it's either an open voltage circuit, or the fuel pump is not grounded. personally, i'm leaning toward the fuel pump chassis ground -
11/24 I suggested paying close attention to the bulk-head connector and also I believe that you likely needed to use a different connector for the pump OR it had to have been changed previously requiring a cut/splice below bulk-head
If it is in the tank, might as well get a sending unit
You've got a bunch of torn-up electrical stuff on the car that you don't seem to know how it happened. Maybe rethink all that doesn't work. Related? Who knows.
What brand and part# did you buy from NAPA for the pump? On the CC tank unit was there any script on the pump that you removed? I'm assuming that the sender came with the pump. It might be interesting to know what is included with their sender.
I have a couple LT5 2-pump trees here and the ground is actually soldered on the flange, the CC sender I've no idea but without removing it he should be able to do what he needs. If he's removed it already the plan might change!!!
