hot wired fuel pump????
run a continuity check from pin A of the relay connector to either side of the FP fuse. run the same check from pin B of the oil pressure switch to the FP fuse. now unplug the fuel pump, and run the same continuity checks from the connector that plugs into the FP. if you do not have continuity with the above checks, you have an issue with the fuse panel, specifically the FP wiring. if the above checks for continuity, the issue is at the pump. there is a 15-pin connector behind the instrument panel -C209 - pay attention to the tan/white wire (fuse panel side) and the mating connector - light blue wire, and connector C237, red wire/red wire - again below the fuse block. if you can, apply 12V at these locations. virtual troubleshooting, even with something this simple can be problematic. just a wild *** guess, but my gut feeling is you may have a connector problem or a grounding issue with the fuel tank itself.
don't be a bubba - fix the existing wiring problem, and NOT power the fuel pump directly - just my 2 cents. keep at it, you'll figure it out. again, good luck my friend....
the oil switch is near distributor. I'm not a fan of backyard repairs, but it would make car operational. I would still try to fix it correctly.
this is the 3-pin connector for the fuel pump. the black wire on the plug in connector is indeed (chassis) ground (circuit ground 150) - run a continuity check to a good ground point. the other two wires go to connector C209 (under the dash, near the fuse panel). pins "L" and "E" respectively, circuit wires 120 and 30 -
run a continuity check on those two wires from the fuel pump connector. circuit wire "120" eventually go back to the FP fuse. run a continuity check. circuit "120" now becomes circuit wire "458" and ties in to the oil pressure switch, the fuel pump relay and the ECM. check wiring continuity...
the third wire of the fuel pump connector is circuit "30" (pink wire) and eventually goes back to the instrument panel LCD display - most likely the fuel gauge - ignore it at this point. do not apply 12V or run a continuity check. . you'll be getting into microcircuits, and might as well leave well enough alone.
use the actual multi-page circuit schematic and systematically check the fuel pump wiring. you only have power and ground to deal with - there has to be an open or ground issue. hang in there....
I don't quite follow some of what you've posted since that thread but I'd back up and start fresh. You mention the new pump runs on bench, somewhere you mentioned 6V.
You never mentioned how you confirmed the "bench run" - pump still attached to the tree or removed from the tree.
I believe you've mentioned 'electrical ain't your forte' so I hadn't posted to this thread. I might know how I'd check but I don't know that I'd try to lead you through it.
Do you know that you're checking the correct relay etc.
It ran (you say) once!!!
http://www.corvette-web-central.com/...etteStart.html
May give some insight to your issue.
Good Luck
