Dynamic Compression Intake closing / opening points
"No different from any other online calculator........they're all wrong.
As to why this is wrong? (yes, I entered some numbers from my unmodified engines and it's wrong by quite a lot)
Varying heat loss with compression, ring leakage as well as an undefined IVC point."
This was the next...
"Did you see the part in your link that says: " temperature must be allowed to return to its prior value for Boyle's Law to hold true."?
Also, you should try another tester. I have encountered several whose Schrader valves have been replaced with normal tire valves; their much heavier springs will produce low readings in a compression gauge."
I mentioned Boyles law because it tends to support your theory of compression vs atmospheric pressure (multiples).
One guy posted that BDC pressure x DCR^1.33 was the formula for POTENTIAL cylinder pressure. 1.33 is the exponential ratio of air I guess. With this formula, it suggests I'd see 250psi during operation of the engine. He added that low cranking speeds and ring leakage were among the reasons you can't measure cranking "potential".
So you can't really use just Boyle's Law to predict this. You need the Ideal Gas law: PV=nRT. That tells us that if all else stays equal, pressure is: 1) inversely proportional to volume, 2) proportional to the mass of air being compressed, 3) and proportional to temperature. Good luck predicting the temperature gain, though! It's significant, though. Just watching the heat waves off an air compressor head will show that, not to mention the usefulness of intercoolers after superchargers. The bottom line is that your cranking pressure should be higher than just PV=PV would predict.
http://rbracing-rsr.com/comprAdvHD.htm
If you want to get a close approximation with just a calculator use this formula
14.7^1.11 X DCR = Cranking compression ratio "Use this when engines have 12 to 1 or less SCR"
14.7^1.15 X DCR = cranking compression ratio "Use this when engines have 12 to 1 or more compression)
The formula change is due to the amount of heating of the air, more compression = more heating which adds in addition pressure. It is an exponential increase so the more compression the larger the multiplier will be. (This is really related to dynamic compression but typically higher compression does = higher DRC but is is dependent on the cam specifications so this is just an estimate)
In the future, I want to avoid suggesting (to anyone) said methods of determining components for "ideal" DCR.
At the very least, I probably need to rerun the cranking test on mine. And, figure out if 150psi is "bad" -- meaning I really undershot intended targets. If stroker builds often land north of 200psi...then it would SEEM I left a lot of efficiency on the table.
Of course, I'm drawing a correlation between DCR and cranking compression. If 210-220psi doesn't detonate, they I question how high DCR can really be? Articles I found suggested 7.5-8.5...which I shot for. Specifically, my build targeted 8.4DCR which would SEEM on the high side -- and ideal for compression/efficiency.
155psi cranking compression seems to imply differently -- IF stock builds are higher as are other stroker builds I've found (with CC listed) on the net).
Mostly, I don't like things that don't make sense...or add up!
Based on actual performance, I had to think it was wrong. OTOH, if it's right, maybe I should pull the motor, insert flat-tops and find out what stupid-high torque is like!
Seriously, I just never expected my compression to be lower than other stroker HP builds. They have "bigger" cams and bleed off MORE than my small-cammed/torque-build. Plus I never considered that it ran like something with low compression.
11.47 is (what I THOUGHT was) rediculously high compression. Why would sites advertise 7.5-8.5 ideal DCR targets, if you can land so much higher and be OK? I assume yours runs on gas?
I can see how much-faster cranking of a battery-charger might affect results. I also have forged pistons (compared to the stock cast), I tested it bone cold so maybe that has a bearing too. (Looser pistons?) Edit: I also have thinner rings. IIRC...they are a 1mm, 1mm, 3mm set.
It would be interesting to do that and get pressure readings at various RPM's. I'd expect TPI to have a noticeably higher reading at 3200 RPM than at idle.
But if your performance is good enough I would be happy to have a strong running performance motor rather than the stock short block any-day. Its kinda spilled milk now and just something to learn by. And on a last note there could have been a math error in your calculation which happens to us all. Maybe disappointing to you now but wont affect the value of the car one dime.
Heck drive it like you stole it and have fun Gregg.
