C4 (L98) Parts help
Thats what i was thinking but i wanted a more professional look on things. i am posting all images that people are requesting to make it easier to identify,
Does the Rear caliper have a Emergency cable going towards it? In 1988 they changed over from the drum inside the rotor to a real cable operated emergency brake. It will help you identify the year of the chassis components.
Did they remove the ABS system from that car?
The sticker that lists the accessories on my Car is under the lid of the center console on my 1988 Coupe.
Do you have any kind of safety inspections in Great Britain? That car would not be legal here without a functioning Emergency brake. Then when the State Emissions testing starts the BIG problems would jump up. Since you have a 1985 engine you would likely not be able to pass the requirements for 1995 emissions. They get tougher each year for most models. Do they have any testing done over there to keep the air clean?
I suspect they started with an earlier model chassis and re-made the car into a 1995 model. I have never known anybody to be able to license a 1985 car as a 1995 car. What did your background check show for the car's history?
I wish you the very best of luck in resolving just what you bought. I hope that it works out in your favor over the long term. Corvettes are a lot of fun to own and maintain. I have 2, a 1968 427 Convertible with four speed and a 1988 Coupe with its L98 running strong.
Merry Christmas and have a wonderful New Year!
Assuming the intake goes with the engine, it's not a Throttle Bore or carb so that leaves out everything prior to 1985. 85 had the cast iron heads as did early 86 (due to the perimeter valve cover bolts). Aluminum heads started with the 86 convertible and late coupes identifiable via the 4 hold down bolts down the middle of the valve covers.
If the engine is a built it's an 85 or early 86 IMO.
This sure looks like it might be an aggregation of multiple cars to make one workable one. It just doesn't add up between all the differences in the car. Maybe pull a wheel and see what the offset on them is and if there are any spacers in there. Another would be look at things like on top of the gas tank and see if the build sheet is still there. If it's a 95 it should have had a LT1, not an L98 engine. Too many things here just don't add up.
The main part i needs that are causing issues are the Radiator and the Alternator. Does anyone know any parts you can link for me to purchase to replace? don't want refurbished. only want new/upgrades.
As long as she runs like a dream and i can have some fun in her I will be happy, that's the target.
Since your car has 5 spoke later wheels you should be able to take snapshots of your calipers through the spokes. That would confirm much. The SPID label in the storage compartment - let's have a better snapshot of it. If that's an '85 SPID it might answer nearly all of that which is unknown. the engine can certainly be identified with information from the block in front of the right cylinder head.
Radiator and alternator WILL NOT BE AN ISSUE!!! Radiator NEW but the 17SI GM alternator is going to likely require either a repair or a rebuilt. I'm quite sure it's a 17SI.
There are several here with '85 cars that would be very likely good to use information from to further ID your engine and chassis. Joe C, Randy M and others. Recently Joe C posted a snapshot of an alternator original identifier on the ear if it were maybe original.
Someone did some very unusual parts swaps and the change of the VIN tag in the windshield. When the snow clears and Spring arrives I'd say you'll enjoy!!
I dont want to sound daft but could you please send me a pic of the exact location you would like snaps of and i will do that first thing in the morning as its dark atm.
Many have put later C4 panels on early cars - nothing ODD about that BUT most wouldn't have changed the windshield VIN plate. Here in the US - Canada etc it's 'illegal' - that's why I asked if it was registered, has passed safety inspections etc. If you're good with that your're fine. I'd think you'll NEVER be able to sell the car as a completely LEGAL driver.
First the well behind the seat looks like an abs unit was pulled - if so that makes the body at least an 86. I don't believe they ran brake lines through it in 1985 along with abs wiring, so that's a giveaway.
Isn't there a stamping on the frame below the battery that should at least partially match the windshield vin?
Is there a pellet on the ignition key - that started in 1986.
Is the parking brake a drum or not?
Wheel backspacing is 32 or 38 depending on rim width on the early C4's, it went to 56mm I believe in 1988.
Isn't there a pad on the engine that has a partial vin that should match the windshield vin if it's an original engine.
Also GM switched to a roller cam instead of a flat tappet cam in 1987, but again AFAIK they all had aluminum heads.
Run out of ideas, hope it helps. Other than identifying correct replacement parts, if you're happy with the car so much the better.
I will take the images of the calipers in a few hours when its day time and post them.
The engine has already been confirmed that has a different VIN to the on in the dashboard window.
Please post any other images that you request to get more info on this car because i am seriously regretting buying this car now but at the same time i love it! (Left hand drive still hard to get used to)
Just want her all shiny, new, upgraded and running smooth with no issues.
Also, with what you have seen in the engine, if you know of any new performance parts that you know will fit. please link them and i will add them to the list to buy over the years.
(Sooner i have her running the better! Named her "Prince" the second i bought her)
Was the car sold to you as a '95? You bought the car where? You mentioned 'runner' so was it shipped to you from somewhere else? Here in the US you would have legal complaints that wouldn't be hard to prove you were the victim of a FRAUDULENT sale!
If you paid '95 prices for an '85 car it's something maybe to consider!
We can explain to you where to find actual identification on the car that would verify the year. It's not a difficult project if you wanted to prove he FRAUDULENT SALE.
I'll bet LHD is tough to get used to. I had an Austin-Healey Sprite "bug-eye" RHD a few years here and it was interesting.
One observation I had is the fancy steering wheel. It appears that the front wheels are straight, but the steering wheel isn't. The steering wheel is mounted on a splined shaft, so the steering wheel can be mounted at any position. Strange problem, but an easy fix. It's interesting that the Vehicle Emission Control label (post #18) says the car is certified for sale in California!!!!
Prince did give us some nice music, but I think Johnny Cash was singing his song just for you!
To ID your engine you can find information here on the engine. I'm thinking you'll find one of these but regardless there's information there that can ID it very accurately. ZDF - ZJB - ZJC - ZJJ - ZJK With the A/T likely ZDF or ZJJ maybe.
There's also a label on your compressor. That could be used for clues also. An '85 should have an 1131476 on the label but in larger numbers just 476. Regardless post the 3 digit and 7 digit numbers you find on the label.
Is this a car you're satisfied with overall and want to keep or not?
If no, then best to sell and move on.
If yes, then from what I remember your main issue is the alternator. You can get rebuild kits, I'm assuming there are places where you're at that rebuild alternators or buy a replacement. There should be some form of numbers on the alternator that identifies is, or look at replacements with the same connections on them.
I'm not up on export model Vettes but the assumption is the engine did not come in the car if it's truly a 90's model (which I doubt), but then again I suppose it's possible it was an engine used in exports. You can tell if the heads are cast or not - try a magnet on them, but with perimeter valve cover bolts sure looks like non-aluminum to me. Maybe look for casting identifiers on the block, might tell something. I still suspect it's an 85, early 86 or crate motor but can't tell for sure.
As far as rust goes, clean up and treat it. It will make you feel better and if you decide to sell it should help in the long run there.
Engine transplants happen all the time. I even one time had a 55 Dodge pickup with a 56 Desoto Hemi in it. Other than figuring out the year of the engine to buy the right parts for it, it was a fun ride and something I wish I still owned.
If the car is something you plan to keep, clean up what you need, maintain what needs maintenance and enjoy the ride. My 86 has a L98 in it also, it's a good solid torquey motor. May not be the fastest one out there, but it's a lot of fun none the less and very dependable overall.
Good luck.
PS not in front of the car at this time, but IIRC there is some form of cover on the outside of the calipers missing in the 2d caliper photo. Wouldn't hurt to get something over them to keep the dirt and brake dust out of them IMO.
Just had one additional thought. I've read where cars were stolen, vins changed then sold overseas. Not saying it is or isn't but it's also a possibility but without more detective work, no way to tell for sure.
