Key chip
Old Dec 15, 2017 | 10:39 PM
MikieG1971's Avatar
MikieG1971
Default Key chip
How does a guy figure out which key/chip to order for his car?
Also, who has the best price on the blanks?
Old Dec 15, 2017 | 10:45 PM
pcolt94's Avatar
pcolt94
Do you have you current key? If you do the locksmith can tell you. Don't go to a dealer, call around for prices of locksmiths.
If you have your current key, you can measure the resistance and check the code key chart and figure it out.
# Value Range are in K ohms (1000)
1 .402 .386-.438
2 .523 .502-.564
3 .681 .650-.728
4 .887 .850-.942
5 1.130 1.085-1.195
6 1.470 1.411-1.549
7 1.870 1.795-1.965
8 2.370 2.275-2.485
9 3.010 2.890-3.150
10 3.740 3.590-3.910
11 4.750 4.560-4.960
12 6.040 5.798-6.302
13 7.500 7.200-7.820
14 9.530 9.149-9.931
15 11.800 11.320-12.290
Old Dec 15, 2017 | 10:47 PM
MikieG1971's Avatar
MikieG1971
So just measure the resistance across the chip with a multimeter?
Where can a guy find this chart?
Old Dec 15, 2017 | 10:57 PM
arbee's Avatar
arbee
Right there in post #2.
Old Dec 16, 2017 | 08:00 AM
Komiller118's Avatar
Komiller118
i used a meter and a chart and got the correct key from ebay for just a couple bucks
Old Dec 16, 2017 | 09:26 AM
MikieG1971's Avatar
MikieG1971
You guys are awesome!
Old Dec 16, 2017 | 09:39 AM
pcolt94's Avatar
pcolt94
What key phrases are used for the search for it?
Are all key blanks the same for all years or what?
Old Dec 16, 2017 | 09:51 AM
arbee's Avatar
arbee
Not sure if this will work but you might start with "vats key blank".
Old Dec 16, 2017 | 10:07 AM
WVZR-1's Avatar
WVZR-1
Single side VATS blanks are the same for any year GM that uses VATS through '96. Some VATS changes to double-sided in '97 - the C5 is an example. I don't believe that any other double-sided preceded '97.
Here's a chart I've seen previously for VATS INFO - I've never used it. I've a GM Interrogator that I've used quite frequently. If you have a dealer do a 'key request' for you they will get a 'letter code' response from GM if it's available. For most years it isn't with the request any longer.
If you meant for an eBay search, then "Strattec XXXXXX" (xxxxxx = part#) will get you results and also include usually the correct associated GM # if you're interested in an OE. If you do Strattec or Briggs & Stratton it will be 'same as' OE. Ilco and others not.
Old Dec 16, 2017 | 05:31 PM
Komiller118
https://www.ebay.com/itm/OEM-NEW-GM-...JWY1n~&vxp=mtr
Old Dec 23, 2017 | 04:27 PM
MikieG1971's Avatar
MikieG1971
Default 2000 ohms
Ok. The meter i used did not have a 1000 setting. So i used the 2000 setting and got 1.858.
So how does this break down? Do we divide or multiply our findings by 2?
Thanks guys.
Old Dec 23, 2017 | 04:54 PM
Benny42's Avatar
Benny42
Thanks guys.
No. Read it directly. You have a #7
Old Dec 23, 2017 | 07:37 PM
MikieG1971's Avatar
MikieG1971
Default Door key
Thanks man! One last question. Which key was used on the 1996 doors?
Old Dec 23, 2017 | 07:49 PM
WVZR-1's Avatar
WVZR-1
I would expect an H but if you have a working key of any vendor it will have the blank on it in some fashion. An OEM key would be on the key blade. All others on the key head I believe.
Old Dec 23, 2017 | 08:24 PM
belairbrian's Avatar
belairbrian
When I went to the local dealer, they couldn't tell me what key I needed because their reader box had broken and couldn't see the value in having it fixed. The VATS system is too old.
They did offer to do the cut for free if I found the correct key and brought them in.
Old Dec 24, 2017 | 09:04 AM
Cjunkie's Avatar
Cjunkie
Just drive it to a locksmith. I took the lazy way. I drove to the locksmith, $20 and 5 minutes later I had a VATS ignition and door key cut and I was down the street.
Old Dec 24, 2017 | 10:17 AM
pcolt94's Avatar
pcolt94
That's how I have done it.
GM doesn't support the C4 anymore and the dealer really does not care about your key and getting their machine fixed even though they might be nice people. Its just a ohm meter in a fancy box. You're going to wait a long time.
Go to the locksmith and get it done and get on with you life.
To Key chip
Old Dec 24, 2017 | 10:32 AM
Cjunkie's Avatar
Cjunkie
I wasn’t exaggerating either. The girl working there checked the resistance on my key, went to the shelf and had it done in 5 mins or less. I went out and tried them, both were spot on. It was $20 and I was done.
Old Dec 26, 2017 | 08:56 PM
MikieG1971's Avatar
MikieG1971
So is there a preferred key brand? See a few on the Bay. I always seem to pick the one that gives me hell.
Old Dec 26, 2017 | 09:29 PM
belairbrian
I bought GM OEM key blanks
