..... BTW ... anything over 400hp naturally aspirated is big enough to be proud of ! ... I'm just curious about what's providing the intake air to the engines of some of our C4's ... anything creative that displays some thinking outside the box qualifies ... that means no stock TPI intakes ... polishing or powder coating is not creative from an air flow standpoint .....
Not aware if one has ever been flow tested.
However, I do know of several LT5s with increased displacement (415, 427, 441 CID) that are making North of 635 hp using the stock TB bored to 63.5mm. Cross section area of a twin 63.5mm TB is more or less equivalent to a single 90mm TB which flow around 1200-1250 CFM according to sources on the internet.
.....Its an Offenhauser Cross Ram ... the top was available in a few different configurations ... single 4bbl , Tri-Power , and Dual Quad ... Edelbrock had a couple versions including the Smokey Ram ... and Chevrolet made one for the early Trans-Am racers ... THIS is the only Offy that I know of that is available in EFI ! ... I also had one of the Smokey Rams converted for EFI .....
