91 heat problem
Old Jan 14, 2018 | 04:40 PM
Marcus123's Avatar
Marcus123
Default 91 heat problem
My heat doesnt work the blower motor works but its just cold im pretty sure theres no sensor on the heater core hose that can be bad like the other cars cold it be the recycled air flow vent/flap that is stuck open to fresh air why else would i not be getting heat i haveny checked my heater core but it cant get completely clogged can it.
Old Jan 14, 2018 | 05:10 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
When the car's up to temp, are your heater hoses hot? If not, you're not getting flow thru the core, so it's either the valve or another obstruction.
